Using vers 1.18.1 on Win8.1
The individual Clublog "upload/update to Clublog" is not working for me.
Anyone else noticed this?
Rob
Clublog update
Clublog update
Rob
HB9ETR / G0IFL
Win10 i5-11400 @ 2.60GHz
HB9ETR / G0IFL
Re: Clublog update
forgot to mention that auto upload is OK.
Rob
HB9ETR / G0IFL
HB9ETR / G0IFL
Re: Clublog update
Hi Rob,
have checked this just a few seconds before. The manual upload is working well like you can see in the attched picture which was showing my latest clublog upload. This was a manual upload so i´ve switched off the automatted upload funktion before in the settings. If you have this enabled and a qso is uploaded automatic after entering to the log the manual upload/update will give only a result if the qso data is changed. If all is the same you would not see any difference at clublog.
- df5ww1.PNG (13.62 KiB) Viewed 6619 times
Re: Clublog update
No, I have something not quite right.
The auto upload was off when I attempted the manual upload...and nothing was sent to Clublog. I have confirmed this by doing a log search of one of the QSOs which shows "N" in the Clublog upload column.
Auto upload works fine.
Rob
HB9ETR / G0IFL
HB9ETR / G0IFL
Re: Clublog update
Check the Log4OM log file (Help/Showlog)HB9ETR wrote:Hi,
It will identify any Clublog errors as illustrated below which was a QSO I tried to upload when it had already been uploaded
2014-08-23 09:09:01.7348 INFO: ClubLogManagement: UPLOAD begin upload QSO Call: G8HQJ Date: 20140806 Time: 072843 Band: 60m Mode: SSB
2014-08-23 09:09:01.7988 INFO: AdifManagement: Begin ClubLog row creation for Call: G8HQJ Date: 20140806 Time: 072843 Band: 60m Mode: SSB
2014-08-23 09:09:01.8188 INFO: AdifManagement: End ClubLog row creation for Call: G8HQJ Date: 20140806 Time: 072843 Band: 60m Mode: SSB
2014-08-23 09:09:01.8438 DEBUG: ClubLogManagement: Upload informations:
email=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
password=XXXXXXXXXXXXXXXcallsign=G4POP&adif=%3cADDRESS%3a83%3e11+Marina+View+%2cLittlehampton+Marina%0d%0aLittlehampton+%2cWest+Sussex%0d%0aBN17+5DS%0d%0aEngland+%3cA_INDEX%3a1%3e0+%3cANT_AZ%3a3%3e225+%3cANT_EL%3a1%3e0+%3cBAND%3a3%3e60m+%3cCALL%3a5%3eG8HQJ+%0d%0a%3cCONT%3a2%3eEU+%3cCOUNTRY%3a7%3eEngland+%3cCQZ%3a2%3e14+%3cDISTANCE%3a3%3e131+%3cDXCC%3a3%3e223+%3cEQSL_QSLSDATE%3a8%3e20140806+%3cEQSL_QSL_RCVD%3a1%3eN+%3cEQSL_QSL_SENT%3a1%3eY+%3cFREQ%3a6%3e5.3985+%3cGRIDSQUARE%3a6%3eIO90RT+%3cIOTA%3a6%3eEU-005+%3cITUZ%3a2%3e27+%3cLOTW_QSLSDATE%3a8%3e20140806+%3cLOTW_QSL_RCVD%3a1%3eN+%3cLOTW_QSL_SENT%3a1%3eY+%0d%0a%3cMODE%3a3%3eSSB+%3cMY_CITY%3a17%3eBurnham+on+Crouch+%3cMY_COUNTRY%3a7%3eEngland+%3cMY_CQ_ZONE%3a2%3e14+%3cMY_GRIDSQUARE%3a6%3eJO01JP+%3cMY_ITU_ZONE%3a2%3e27+%3cMY_NAME%3a11%3eTerry+Genes+%3cMY_POSTAL_CODE%3a7%3eCM0+8EY+%3cMY_RIG%3a17%3eIcom+IC756+ProIII+%3cMY_STREET%3a16%3e28+Hillside+Road+%3cNAME%3a5%3eBarry+%3cOPERATOR%3a5%3eG4POP+%3cOWNER_CALLSIGN%3a5%3eG4POP+%3cSTATION_CALLSIGN%3a5%3eG4POP+%3cPROGRAMID%3a6%3eLog4OM+%3cPROGRAMVERSION%3a8%3e1.18.1.0+%3cQSL_RCVD%3a1%3eN+%3cQSL_SENT%3a1%3eN+%0d%0a%3cQSO_DATE%3a8%3e20140806+%3cQTH%3a26%3eLittlehampton+%2cWest+Sussex+%3cRST_RCVD%3a2%3e59+%3cRST_SENT%3a2%3e59+%3cRX_PWR%3a1%3e0+%3cSAT_MODE%3a3%3eSSB+%3cTIME_OFF%3a6%3e072954+%3cTIME_ON%3a6%3e072843+%3cTX_PWR%3a3%3e100+%3cA_INDEX%3a1%3e0+%3cFORCE_INIT%3a1%3e0+%3cK_INDEX%3a1%3e0+%3cMAX_BURSTS%3a1%3e0+%3cNR_BURSTS%3a1%3e0+%3cNR_PINGS%3a1%3e0+%3cPFX%3a1%3eG+%3cSFI%3a1%3e0+%3cEOR%3e%0d%0a&api=6e41673971f683ba4e54d124350320ce4c6bbe0e
2014-08-23 09:09:02.1848 ERROR: *** ClubLogManagement: upload caught in error with code: Dupe
DO NOT POST YOU LOG FILE ON THE FORUM BECAUSE IT WILL CONTAIN YOUR PRIVATE INFORMATION
Re: Clublog update
had to make a quick contact to be sure I was taking the right bit of info
2014-08-23 10:27:01.5896 INFO: ClubLogManagement: UPLOAD begin upload QSO Call: OK1SG Date: 20140823 Time: 092200 Band: 20m Mode: PSK31
2014-08-23 10:27:01.5946 INFO: AdifManagement: Begin ClubLog row creation for Call: OK1SG Date: 20140823 Time: 092200 Band: 20m Mode: PSK31
2014-08-23 10:27:01.5996 INFO: AdifManagement: End ClubLog row creation for Call: OK1SG Date: 20140823 Time: 092200 Band: 20m Mode: PSK31
2014-08-23 10:27:01.6036 DEBUG: ClubLogManagement: Upload informations:
email=xxxxxxxxx&password=xxxxxxxxxx&callsign=HB9ETR&adif=%3cADDRESS%3a45%3eZahradn%c3%ad+270%0d%0aPot%c2%9atejn%0d%0a51743%0d%0aCzech+Republic+%3cA_INDEX%3a1%3e0+%3cANT_AZ%3a2%3e60+%3cANT_EL%3a1%3e0+%3cBAND%3a3%3e20m+%3cCALL%3a5%3eOK1SG+%0d%0a%3cCONT%3a2%3eEU+%3cCOUNTRY%3a14%3eCzech+Republic+%3cCQZ%3a2%3e15+%3cDISTANCE%3a3%3e638+%3cDXCC%3a3%3e503+%3cEQSL_QSL_RCVD%3a1%3eN+%3cEQSL_QSL_SENT%3a1%3eN+%3cFREQ%3a9%3e14.071296+%3cGRIDSQUARE%3a6%3eJO80dc+%3cITUZ%3a2%3e28+%3cLOTW_QSL_RCVD%3a1%3eN+%3cLOTW_QSL_SENT%3a1%3eN+%0d%0a%3cMODE%3a5%3ePSK31+%3cMY_CITY%3a11%3eGlattfelden+%3cMY_CNTY%3a11%3eSwitzerland+%3cMY_COUNTRY%3a11%3eSwitzerland+%3cMY_CQ_ZONE%3a2%3e14+%3cMY_GRIDSQUARE%3a6%3eJN47FN+%3cMY_ITU_ZONE%3a2%3e28+%3cMY_NAME%3a3%3eRob+%3cMY_RIG%3a2%3eK3+%3cNAME%3a6%3eVictor+%3cOPERATOR%3a6%3eHB9ETR+%3cOWNER_CALLSIGN%3a6%3eHB9ETR+%3cSTATION_CALLSIGN%3a6%3eHB9ETR+%3cPROGRAMID%3a6%3eLog4OM+%3cPROGRAMVERSION%3a8%3e1.18.1.0+%3cQSL_RCVD%3a1%3eN+%3cQSL_SENT%3a1%3eN+%3cQSL_VIA%3a20%3eVIA+BUREAU+OR+DIRECT+%0d%0a%3cQSO_DATE%3a8%3e20140823+%3cQSO_DATE_OFF%3a8%3e20140823+%3cQTH%3a8%3ePot%ef%bf%bdtejn+%3cRST_RCVD%3a3%3e599+%3cRST_SENT%3a3%3e599+%3cRX_PWR%3a1%3e0+%3cTIME_OFF%3a6%3e092644+%3cTIME_ON%3a6%3e092200+%3cTX_PWR%3a2%3e50+%3cA_INDEX%3a1%3e0+%3cFORCE_INIT%3a1%3e0+%3cK_INDEX%3a1%3e0+%3cMAX_BURSTS%3a1%3e0+%3cNR_BURSTS%3a1%3e0+%3cNR_PINGS%3a1%3e0+%3cPFX%3a2%3eOK+%3cSFI%3a1%3e0+%3cEOR%3e%0d%0a&api=6e41673971f683ba4e54d124350320ce4c6bbe0e
2014-08-23 10:27:06.6239 ERROR: *** ClubLogManagement: Upload to ClubLog caught in error ******* [Function: sendLogThread_DoWork] System.Net.WebException: The operation has timed out
at LogOM.BL.ClubLogManagement.DoSend(QSO qso, String url, String email, String callsign, String password, String apiKey)
at LogOM.BL.ClubLogManagement.sendLogThread_DoWork(Object sender, DoWorkEventArgs e)
2014-08-23 10:27:06.6289 ERROR: *** ClubLogManagement: upload caught in error with code:
Rob
HB9ETR / G0IFL
HB9ETR / G0IFL
Re: Clublog update
Looks like your email and/or password for Clublog are entered incorrectly in Log4om - Make sure you are using the correct caseHB9ETR wrote:had to make a quick contact to be sure I was taking the right bit of info
Re: Clublog update
think that could not be. He wrotes that the automatic upload is working fine and mail & password are the same in automatic and manuel upload
Must be another mistake ....
Here the manual upload is working fine and the automatted upload too. Checked this when i read this post here this morning. OS here Win 7 Ultimate 64 Bit.
Re: Clublog update
no, I don't think its that as the auto upload should not work in that case (I guess)
nonetheless, I did recheck and it is as it should be.
Rob
HB9ETR / G0IFL
HB9ETR / G0IFL
Re: Clublog update
Very strange that it works fine for both of us but not for you, are you certain that the auto upload is working for you?HB9ETR wrote:no, I don't think its that as the auto upload should not work in that case (I guess)
