Clublog update
HB9ETR
Clublog update
Post by HB9ETR »
Using vers 1.18.1 on Win8.1
The individual Clublog "upload/update to Clublog" is not working for me.
Anyone else noticed this?
Rob
Rob
HB9ETR / G0IFL
K3/Win4K3Suite/OnmiRig/L4OM v2.33.0.0
Win10 i5-11400 @ 2.60GHz
HB9ETR
Re: Clublog update
Post by HB9ETR »
forgot to mention that auto upload is OK.
Rob
HB9ETR / G0IFL
Re: Clublog update
Hi Rob,
have checked this just a few seconds before. The manual upload is working well like you can see in the attched picture which was showing my latest clublog upload. This was a manual upload so i´ve switched off the automatted upload funktion before in the settings. If you have this enabled and a qso is uploaded automatic after entering to the log the manual upload/update will give only a result if the qso data is changed. If all is the same you would not see any difference at clublog.
HB9ETR
Re: Clublog update
Post by HB9ETR »
No, I have something not quite right.
The auto upload was off when I attempted the manual upload...and nothing was sent to Clublog. I have confirmed this by doing a log search of one of the QSOs which shows "N" in the Clublog upload column.
Auto upload works fine.
Rob
HB9ETR / G0IFL
Re: Clublog update
HB9ETR wrote:Hi,
Check the Log4OM log file (Help/Showlog)
It will identify any Clublog errors as illustrated below which was a QSO I tried to upload when it had already been uploaded
2014-08-23 09:09:01.7348 INFO: ClubLogManagement: UPLOAD begin upload QSO Call: G8HQJ Date: 20140806 Time: 072843 Band: 60m Mode: SSB
2014-08-23 09:09:01.7988 INFO: AdifManagement: Begin ClubLog row creation for Call: G8HQJ Date: 20140806 Time: 072843 Band: 60m Mode: SSB
2014-08-23 09:09:01.8188 INFO: AdifManagement: End ClubLog row creation for Call: G8HQJ Date: 20140806 Time: 072843 Band: 60m Mode: SSB
2014-08-23 09:09:01.8438 DEBUG: ClubLogManagement: Upload informations:
email=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
password=XXXXXXXXXXXXXXXcallsign=G4POP&adif=%3cADDRESS%3a83%3e11+Marina+View+%2cLittlehampton+Marina%0d%0aLittlehampton+%2cWest+Sussex%0d%0aBN17+5DS%0d%0aEngland+%3cA_INDEX%3a1%3e0+%3cANT_AZ%3a3%3e225+%3cANT_EL%3a1%3e0+%3cBAND%3a3%3e60m+%3cCALL%3a5%3eG8HQJ+%0d%0a%3cCONT%3a2%3eEU+%3cCOUNTRY%3a7%3eEngland+%3cCQZ%3a2%3e14+%3cDISTANCE%3a3%3e131+%3cDXCC%3a3%3e223+%3cEQSL_QSLSDATE%3a8%3e20140806+%3cEQSL_QSL_RCVD%3a1%3eN+%3cEQSL_QSL_SENT%3a1%3eY+%3cFREQ%3a6%3e5.3985+%3cGRIDSQUARE%3a6%3eIO90RT+%3cIOTA%3a6%3eEU-005+%3cITUZ%3a2%3e27+%3cLOTW_QSLSDATE%3a8%3e20140806+%3cLOTW_QSL_RCVD%3a1%3eN+%3cLOTW_QSL_SENT%3a1%3eY+%0d%0a%3cMODE%3a3%3eSSB+%3cMY_CITY%3a17%3eBurnham+on+Crouch+%3cMY_COUNTRY%3a7%3eEngland+%3cMY_CQ_ZONE%3a2%3e14+%3cMY_GRIDSQUARE%3a6%3eJO01JP+%3cMY_ITU_ZONE%3a2%3e27+%3cMY_NAME%3a11%3eTerry+Genes+%3cMY_POSTAL_CODE%3a7%3eCM0+8EY+%3cMY_RIG%3a17%3eIcom+IC756+ProIII+%3cMY_STREET%3a16%3e28+Hillside+Road+%3cNAME%3a5%3eBarry+%3cOPERATOR%3a5%3eG4POP+%3cOWNER_CALLSIGN%3a5%3eG4POP+%3cSTATION_CALLSIGN%3a5%3eG4POP+%3cPROGRAMID%3a6%3eLog4OM+%3cPROGRAMVERSION%3a8%3e1.18.1.0+%3cQSL_RCVD%3a1%3eN+%3cQSL_SENT%3a1%3eN+%0d%0a%3cQSO_DATE%3a8%3e20140806+%3cQTH%3a26%3eLittlehampton+%2cWest+Sussex+%3cRST_RCVD%3a2%3e59+%3cRST_SENT%3a2%3e59+%3cRX_PWR%3a1%3e0+%3cSAT_MODE%3a3%3eSSB+%3cTIME_OFF%3a6%3e072954+%3cTIME_ON%3a6%3e072843+%3cTX_PWR%3a3%3e100+%3cA_INDEX%3a1%3e0+%3cFORCE_INIT%3a1%3e0+%3cK_INDEX%3a1%3e0+%3cMAX_BURSTS%3a1%3e0+%3cNR_BURSTS%3a1%3e0+%3cNR_PINGS%3a1%3e0+%3cPFX%3a1%3eG+%3cSFI%3a1%3e0+%3cEOR%3e%0d%0a&api=6e41673971f683ba4e54d124350320ce4c6bbe0e
2014-08-23 09:09:02.1848 ERROR: *** ClubLogManagement: upload caught in error with code: Dupe
DO NOT POST YOU LOG FILE ON THE FORUM BECAUSE IT WILL CONTAIN YOUR PRIVATE INFORMATION
HB9ETR
Re: Clublog update
Post by HB9ETR »
had to make a quick contact to be sure I was taking the right bit of info :)
2014-08-23 10:27:01.5896 INFO: ClubLogManagement: UPLOAD begin upload QSO Call: OK1SG Date: 20140823 Time: 092200 Band: 20m Mode: PSK31
2014-08-23 10:27:01.5946 INFO: AdifManagement: Begin ClubLog row creation for Call: OK1SG Date: 20140823 Time: 092200 Band: 20m Mode: PSK31
2014-08-23 10:27:01.5996 INFO: AdifManagement: End ClubLog row creation for Call: OK1SG Date: 20140823 Time: 092200 Band: 20m Mode: PSK31
2014-08-23 10:27:01.6036 DEBUG: ClubLogManagement: Upload informations:
email=xxxxxxxxx&password=xxxxxxxxxx&callsign=HB9ETR&adif=%3cADDRESS%3a45%3eZahradn%c3%ad+270%0d%0aPot%c2%9atejn%0d%0a51743%0d%0aCzech+Republic+%3cA_INDEX%3a1%3e0+%3cANT_AZ%3a2%3e60+%3cANT_EL%3a1%3e0+%3cBAND%3a3%3e20m+%3cCALL%3a5%3eOK1SG+%0d%0a%3cCONT%3a2%3eEU+%3cCOUNTRY%3a14%3eCzech+Republic+%3cCQZ%3a2%3e15+%3cDISTANCE%3a3%3e638+%3cDXCC%3a3%3e503+%3cEQSL_QSL_RCVD%3a1%3eN+%3cEQSL_QSL_SENT%3a1%3eN+%3cFREQ%3a9%3e14.071296+%3cGRIDSQUARE%3a6%3eJO80dc+%3cITUZ%3a2%3e28+%3cLOTW_QSL_RCVD%3a1%3eN+%3cLOTW_QSL_SENT%3a1%3eN+%0d%0a%3cMODE%3a5%3ePSK31+%3cMY_CITY%3a11%3eGlattfelden+%3cMY_CNTY%3a11%3eSwitzerland+%3cMY_COUNTRY%3a11%3eSwitzerland+%3cMY_CQ_ZONE%3a2%3e14+%3cMY_GRIDSQUARE%3a6%3eJN47FN+%3cMY_ITU_ZONE%3a2%3e28+%3cMY_NAME%3a3%3eRob+%3cMY_RIG%3a2%3eK3+%3cNAME%3a6%3eVictor+%3cOPERATOR%3a6%3eHB9ETR+%3cOWNER_CALLSIGN%3a6%3eHB9ETR+%3cSTATION_CALLSIGN%3a6%3eHB9ETR+%3cPROGRAMID%3a6%3eLog4OM+%3cPROGRAMVERSION%3a8%3e1.18.1.0+%3cQSL_RCVD%3a1%3eN+%3cQSL_SENT%3a1%3eN+%3cQSL_VIA%3a20%3eVIA+BUREAU+OR+DIRECT+%0d%0a%3cQSO_DATE%3a8%3e20140823+%3cQSO_DATE_OFF%3a8%3e20140823+%3cQTH%3a8%3ePot%ef%bf%bdtejn+%3cRST_RCVD%3a3%3e599+%3cRST_SENT%3a3%3e599+%3cRX_PWR%3a1%3e0+%3cTIME_OFF%3a6%3e092644+%3cTIME_ON%3a6%3e092200+%3cTX_PWR%3a2%3e50+%3cA_INDEX%3a1%3e0+%3cFORCE_INIT%3a1%3e0+%3cK_INDEX%3a1%3e0+%3cMAX_BURSTS%3a1%3e0+%3cNR_BURSTS%3a1%3e0+%3cNR_PINGS%3a1%3e0+%3cPFX%3a2%3eOK+%3cSFI%3a1%3e0+%3cEOR%3e%0d%0a&api=6e41673971f683ba4e54d124350320ce4c6bbe0e
2014-08-23 10:27:06.6239 ERROR: *** ClubLogManagement: Upload to ClubLog caught in error ******* [Function: sendLogThread_DoWork] System.Net.WebException: The operation has timed out
at LogOM.BL.ClubLogManagement.DoSend(QSO qso, String url, String email, String callsign, String password, String apiKey)
at LogOM.BL.ClubLogManagement.sendLogThread_DoWork(Object sender, DoWorkEventArgs e)
2014-08-23 10:27:06.6289 ERROR: *** ClubLogManagement: upload caught in error with code:
Rob
HB9ETR / G0IFL
Re: Clublog update
HB9ETR wrote:had to make a quick contact to be sure I was taking the right bit of info :)
Looks like your email and/or password for Clublog are entered incorrectly in Log4om - Make sure you are using the correct case
Re: Clublog update
think that could not be. He wrotes that the automatic upload is working fine and mail & password are the same in automatic and manuel upload ;)
Must be another mistake .... :?
Here the manual upload is working fine and the automatted upload too. Checked this when i read this post here this morning. OS here Win 7 Ultimate 64 Bit.
HB9ETR
Re: Clublog update
Post by HB9ETR »
no, I don't think its that as the auto upload should not work in that case (I guess)
nonetheless, I did recheck and it is as it should be.
Rob
HB9ETR / G0IFL
Re: Clublog update
HB9ETR wrote:no, I don't think its that as the auto upload should not work in that case (I guess)
Very strange that it works fine for both of us but not for you, are you certain that the auto upload is working for you?
