RTTY?
G4DWV
Re: RTTY?
Post by G4DWV »
G4POP wrote:I am using MixW for FSK and then I export an ADIF for import into Log4OM
Anything to watch for when doing this? Any gotchas?
Re: RTTY?
No it's quiet straightforward just set up MiXW for FSK RTTY making sure you use the correct port for the FSK controller, your interface instruction will explain the set up.
After an FSK RTTY session just export the new QSO's as an ADIF from MiXW and then import the ADIF into Log4om
G4DWV
Re: RTTY?
Post by G4DWV »
Thanks.
Re: RTTY?
Don´t forget if you make an ADIF import from other loggers ... Theer will be not an automatted upload to eQSL, HRDlog or qrz.com or Clublog ... You have to upload the contacts manually to those sites :!: :!:
G4DWV
Re: RTTY?
Post by G4DWV »
DF5WW wrote:Don´t forget if you make an ADIF import from other loggers ... Theer will be not an automatted upload to eQSL, HRDlog or qrz.com or Clublog ... You have to upload the contacts manually to those sites :!: :!:
Thanks Juergen
