qrz.com time
ta1o
Re: qrz.com time
Post by ta1o »
Finally i solved the problem,
Problem about time formats, we use d/M/yyyy in Turkey, but log4om dosent work under these formats,
Now i changed time format then it is work properyl.
G4DWV
Re: qrz.com time
Post by G4DWV »
You may be on the right track. From what you have said, we use the same date format in the UK. Look at my settings for the date which ARE working FB. There are some differences between your desired settings and mine which work, but much less than the differences between your desired and working settings. Maybe the UK will work for you, unless you use the date in batch files.
73 de Guy G4DWV/4X1LT
Re: qrz.com time
It's very strange, because log4om doesn't use the user format, but the "raw data" related to time provided from Windows...
I must check that part. Thanks for pointing out
