Add Band for Awards / DXCC
Re: Add Band for Awards / DXCC
If you check LotW page you will see that there are only these awards. There is no special
award for satellites in the DXCC and also no DXCC above 148 MHz. If you need to check
for worked countries on satellite you can create an own "Award" with the Award Manager
funktions.
ON7CL
Post by ON7CL »
I don't know, I just want to see how many DXCC I worked on the Sat ;)
If you open Statistics & Awards and open the TAB "Country/QSO status grid you will see also the 13/3 cm Bands ... ;) ;)
ON7CL
Post by ON7CL »
Thats right, then you have to count yourself :)
Yes, or you create your own award with the award manager for that count ;) 8-)
ON7CL wrote: 04 Aug 2019, 10:49 Thats right, then you have to count yourself :)
You can modify the file to make it non standard DXCC but it will be overwritten every time you update log4OM so make sure that you save a copy of the file to somewhere that is safe.
If you have problems modifying the file let me know what bands you need added and I will make you a file.
ON7CL
Post by ON7CL »
Hmm, creating one for QO-100 with only DXCC and GRID locators looks interesting, but how ?
ON7CL wrote: 04 Aug 2019, 11:20 Hmm, creating one for QO-100 with only DXCC and GRID locators looks interesting, but how ?
Modify the awards.xml file in the C:\Users\YOUR USER NAME\AppData\Roaming\LogOM folder
ON7CL
Post by ON7CL »
I modified the awards.xml file and for the DXCC that is working, I can now see my DXCC for QO-100 Sat.
I'm looking now to do the same so I can see my worked grids on the bands, not all together, is that possible ?
Thanks for reply.
Rudi / ON7CL
ON7CL wrote: 07 Aug 2019, 15:35 Hi,
Thanks for reply.
Rudi / ON7CL
No that would need hard coding, best wait for version 2
