V2 Station Information
N9FB
Re: V2 Station Information
Post by N9FB »
Since I dont need LOG4OM V2 to look up a membership number for me (it is something I lookup externally and enter into the logging program myself anyway), a workaround i found is this: i will just input the respective club # in the "Comment" section because then it does shows up in the columns displayed when I choose the "Recent QSOs (F7)" tab. From there I can also detach the QSO's for review or copy them into a spreadsheet for further analysis.
Rob,
Good evening. BTW - check your gmail account as I sent you a message from my e-mail at 05:48 this AM.
Anyway, below are a couple links for some of the data you might be looking for. You might be able to download files as well.
SKCC Membership Roster: https://www.skccgroup.com/membership_da ... roster.php
SKCC Member Lookup: https://www.skccgroup.com/membership_da ... r_info.php
OMISS Roster Information: http://www.omiss.net/Facelift/rosters.php
Under current V2 configuration I put the SKCC name and number in the drop-down area at the F5 Tab. I also put the OMs SKCC # in the Notes field.
You've noted a good plan to work around certain elements that we have not yet turned on in V2.
Thanks much for you questions and observations.
W8ES
Post by W8ES »
If you're interested in downloading the SKCC membership database, you can find it here:
https://www.skccgroup.com/search/skcclist.txt
KA4CDN
Post by KA4CDN »
How can I create a filter to search the value selected for "Contact Clubs & Assoc's" (chosen in the "Extended info F5" when logging the QSO)?
In "Standard Fields" in the filter dialog I see a ContactAssociations but that doesn't seem to be it. (What is it?
I can not find in the user manual Log4OM's schema so can't use the custom query.
Log4OM version 2.10.0.0
Manual: Updated: 18/12/2020 7:17 PM
Mike
KA4CDN wrote: 08 Jan 2021, 12:01 How can I create a filter to search the value selected for "Contact Clubs & Assoc's" (chosen in the "Extended info F5" when logging the QSO)?
Mike
This facility of viewing and filtering has yet to be added
KA4CDN
Post by KA4CDN »
Thank you Terry.
Has any thought been given to providing a technical document to the database schema so that users can construct custom queries?
