Error uploading to LoTW
Re: Error uploading to LoTW
VA3XOV wrote: 12 Apr 2020, 17:00 I am getting the same error. First time it was ITU zone error. I fixed this. Now it is giving me a Province issue. In TQSL and in LOG4OM, I have Ontario as my province. But the error states Error as Line 10 has ON but QSO has Ontario. When I hit Ignore, it hangs. after 15 minutes I closed the window. Any ideas? Thanks
I edited my QSOs with the proper two-letter configuration. I only had a few to do so wasn't a huge impact and I didn't have to consider a "bulk" update.
K5EY
Post by K5EY »
Try telling TQSL to ignore your station details:
TQSL Ignore Station.png (53.64 KiB) Viewed 3689 times
Charlie -- K5EY
Denton, Texas USA
Log4OM 2 (ver. 2.14.1.0)
Using JTDX (ver. 2.2.156) and JTAlert (ver. 2.50.1)
Intel Core i7-8700 @3.20 GHz (12GB RAM)
Windows 21H1
VA3XOV
Post by VA3XOV »
I finally got it working. I uninstalled TQSL V2.5.2 and re-installed V2.5.1 Success!!! It now works perfectly. All is well again.
k3maw
Post by k3maw »
Where did you find 2.5.1? I can't seem to locate it.
Mike - K3MAW
VA3XOV
Post by VA3XOV »
Hi Mike,
I emailed LOTW help desk with my issue, and in their reply they gave me the link to the older versions. Email info below.
If you are unable to correct a data element, you can reinstall an earlier version TQSL.
Here are links to older TQSL versions:
http://www.arrl.org/files/file/LoTW Instructions/tqsl-2.5.1.msi
http://www.arrl.org/files/file/LoTW Instructions/tqsl-2.4.7.msi
VA3XOV
Post by VA3XOV »
When I copied the link it took out %20 from the link. this is the correct link;
http://www.arrl.org/files/file/LoTW%20I ... -2.5.1.msi
ve2fzp
Post by ve2fzp »
Hello! VA3XOV
Thanks for the info about the place
where to download version 2.5.1
I did like you and came back to this
version and everything works as before.
Thanks again
Gerald ve2fzp
73 '
