BTW
IMPORTANT: JT65 does NOT trigger the PTT when using Omnirig the user must either enter a PTT com port in the “PTT Port” field of JT65 or use VOX
Someone can help me?: Log4OM + JT65HF-Comfort + JTAlert
Re: Someone can help me?: Log4OM + JT65HF-Comfort + JTAlert
Hi Terry, thanks for the reply and sorry for my delay!
But I not perfectly understand your reply, you say that I not need integration from and to JTAlert and JT65HF-Comfort on Log4OM Communicator?
Pratically JT65HF-Comfort realizes the QSO, JTAlert read the data of the QSO and then write the QSO on the Log of Log4OM, this is correct?
Please can you add some info on my screenshoots?
Thanks, Camillo iz6gvc
73s, Camillo
Terry, JT65HF-Comfort is a bit different to JT65HF.G4POP wrote:BTW
JT65HF-Comfort on my setup with Omnirig, send the radio on PTT.
Regards, Camillo iz6gvc
73s, Camillo
iz6gvc wrote:Terry, JT65HF-Comfort is a bit different to JT65HF.G4POP wrote:BTW
Camillo,
Please provide a link to the download for the version that you use 3.8? I cannot find a download link in English and the German one I found needs a login
I will then try it out to see what is happening
Hi Terry, please send me one mail to my adress on QRZ.com .
73s, Camillo iz6gvc
73s, Camillo iz6gvc
73s, Camillo
