Can this be done?
Re: Can this be done?
Never tried that software but if it's another rip-off of WSJT then the same should work
M7DJK
Post by M7DJK »
Its said to be a fork from WSJT - it does look similar but the logbook does not reflect the station being worked at all. I might follow this up on JS8Call support just for education ;)
M7DJK wrote: 23 Aug 2020, 11:03 Its said to be a fork from WSJT - it does look similar but the logbook does not reflect the station being worked at all. I might follow this up on JS8Call support just for education ;)
And the rapid response from JS8CALL was??????
M7DJK
Post by M7DJK »
LOL, the only reply i got was.....
JS8Call emits a different format. Log4OM could interpret those, but it’s up to them to build that.
So I gave up, not very helpful at all really ;)
HI8SMX
Post by HI8SMX »
G4POP wrote: 22 Aug 2020, 14:55 Assuming that you followed the set up instructions in the Log4OM user guide this will be the result
Terry, good night. Let me jump in here for one second. This feature works for me fine, but the transmitting cycle changes (to RX) the info clears from Qso data and when it goes into TX it populates again. This is during same qso. Is this normal or do I need to check something.
73, Santiago
______________
73 de Santiago
HI8O (former HI8SMX) + KB8SM
web: www.hamworld.online
YouTube: hamworldonline
Twitter: @hamworldonline
Instagram: hamworldonline
Sounds like RF in the shack
