Re: Cannot Give Granted Status To Old QSO's
Posted: 21 Nov 2020, 22:43
OK, we must be living in two different realities
First off I did as you suggested and re-installed 2.10.0.0. Started up Log4OM before applying the award fix and everything in the DXCC/Phone matrix looked pretty normal as shown here:
http://k7kb.net/pictures/L4OM_Phone_B4_Fix.JPG
We will just concentrate on the top line for Canada. Next, I went into Settings/Update Resources/Log4OM awards to load in the updated awards and then brought up the matrix as shown here:
http://k7kb.net/pictures/L4OM_Phone_After_Fix.JPG
As you can see, it's completely different than before the fix. Those V contacts shown for Canada on 160 shouldn't even appear as they are all FT8 QSO's, not phone.
As I mentioned previously, the same thing is happening with CW QSO's as shown in this pre-fix image:
http://k7kb.net/pictures/L4OM_CW_B4_Fix.JPG
And after the fix is applied:
http://k7kb.net/pictures/L4OM_CW_After_Fix.JPG
So in conclusion, you may have fixed the original problem I wrote about, but the only thing I can see is that you may have introduced a new problem in the process. And just to let you know, I did a complete clean re-install of Log4OM as I deleted everything in the AppData/Roaming/Log4OM2 folder so I had to start from scratch but it still didn't solve the problem of what I'm seeing with the award matrix.
Hmmmm, I just tried to show some pictures using the "
" tags and they didn't show up. All I'm getting is a Image placeholder without the image actually appearing. The URL's for the images are good.
I'll just go ahead and post them as links instead I guess.
John K7KB
John K7KB
