Cluster Spot Filtering
VA7RPE
Re: Cluster Spot Filtering
Post by VA7RPE »
Hi Nolan,
I tried something a little different. This may make it clearer, or probably more confusing. In CC User I changed the server setting to reject all states expect the ones I want (previously I had set it to accept only the ones I want).
CC User settings:
VE7CC Cluster Exclusion Settings.jpg (153.59 KiB) Viewed 1234 times
Here are the spot results inside CC User:
VE7CC Cluster report.jpg (238.12 KiB) Viewed 1234 times
Log4OM reports no spots. Here is the Management Tab of the cluster:
Log4OM Cluster report.jpg (193.89 KiB) Viewed 1234 times
DJ9UN
Post by DJ9UN »
Wow, id dont go so deply, my issue is that putting the filters in the cluster to have only Station in phone still have FT 8. Perhaps i did something wrong .
