Upload to LOTW
KI7ZOA
Re: Upload to LOTW
Post by KI7ZOA »
Thanks to all who have helped me. I now have my pwd problem sorted, (forgot that I had a separate pwd for LOTW).
n4hcr
Re: Upload to LOTW
Post by n4hcr »
I'm having a similar problem. My QSOs stopped uploading in October, and since then nothing shows up in LOTW. Apparently the upload is being attempted, but it doesn't show up in LOTW. I've checked everything in the manual, I've asked the people at LOTW, I've attempted manual uploads. Nothing has worked.
Ideas appreciated.
Wayne N4HCR
Re: Upload to LOTW
Sounds like either your tqsl cert expired, tqsl is incorrectly set up due to a tqsl update but without knowing what Log4om and tqsl version numbers you are using its hard to help
n4hcr
Re: Upload to LOTW
Post by n4hcr »
The TSQL version is V2.5.7 Trusted QSL Library V2.5
Configuration data V11.13
Log4OM2 v.2.11.0.0
What else do you need?
WR
Re: Upload to LOTW
Set Log4OM trace mode - In the help menu
Try another MANUAL upload to LOTW
Send me the Upload log file and main log file
Upload log file can be saved from the LOTW upload window
The main log file is available in the help menu
DO NOT POST THES ON THE FORUM - email them to me at g4pop (AT) arrl.net
n4hcr
Re: Upload to LOTW
Post by n4hcr »
Thanks Terry,
I'll give that a shot.
Wayne N4HCR
Re: Upload to LOTW
n4hcr wrote: 10 Mar 2021, 05:28 Thanks Terry,
Wayne N4HCR
Your email received and I found that these lines in the upload log tells me what the issue is
“The Station Location 'US County' has value 'Amherst' while QSO has 'USA' on line 9”
Your own ‘US County’’ does not match the TQSL Station Location ‘US County’ field
You need to edit your QSO’s so that your county is ‘Amherst’ not USA it will then match what LOTW are expecting.
This is not caused by Log4OM it is because TQSL tightened up the security to match your station details better during uploads and this happened when TQSL was updated.
n4hcr
Re: Upload to LOTW
Post by n4hcr »
Thanks Terry, I guess that explains it. Now to fix it. Hopefully there's a way to simply replace the value in the "My Cnty" column with Amherst.
Wayne, N4HCR
Re: Upload to LOTW
n4hcr wrote: 10 Mar 2021, 16:23 Thanks Terry, I guess that explains it. Now to fix it. Hopefully there's a way to simply replace the value in the "My Cnty" column with Amherst.
Wayne, N4HCR
Check your TQSL settings first
Re: Upload to LOTW
n4hcr wrote: 10 Mar 2021, 16:23 Hopefully there's a way to simply replace the value in the "My Cnty" column with Amherst.
QSO Manager set a filter (My CNTY - Not Equal to - Click plus sign)
Select/deselect button to select all
Two (FILEminimizer).jpg (239.54 KiB) Viewed 3196 times
Single field edit - 1 Select the field, 2 enter your county, 3 click update
Finished - should take a couple of minutes
