LOTW upload
Re: LOTW upload
Did you check the LOTW settings in Log4OM correspond to the TQSL exe path and temporary file path.
Did you try a direct upload using TQSL?
K0AY
Re: LOTW upload
Post by K0AY »
I also am having the same problem, I have the latest TQSL but contacts from Wsjt-x do not get logged
Re: LOTW upload
Check this thread .... viewtopic.php?f=32&t=6807&start=40
K0AY
Re: LOTW upload
Post by K0AY »
When I uppload to LOTW, I get an error message that says, among other things, that I have the wrong ITU number. I looked it upon the web, it should be 2 for north America, but on the setup page, it allows only 6, 7, or 8.What am I doing wrong?
Re: LOTW upload
Your confusing ITU ZONE with IARU region
There are threads on this forum about the zone issue with LOTW please refer to them for clarification
F6EXV
Re: LOTW upload
Post by F6EXV »
G4POP wrote: 30 Jul 2021, 18:08 Your confusing ITU ZONE with IARU region
03, 04, 05 are for the WAZ award, not IARU ...
Thanks + 73
Paul F6EXV
Re: LOTW upload
Read correct Paul,
the thread opener wrote "It must be 2 for Noth America" but there is no Zone 2 in the USA. There is only
the IARU Region which has a 2 for NA.
F6EXV
Re: LOTW upload
Post by F6EXV »
Hi
I do not think there is any mention of IARU zone in LoTW, anywhere...
Thanks + 73
Paul F6EXV
K0AY
Re: LOTW upload
Post by K0AY »
I too was having trouble with v15. I went back to v7 and it works ok. Then I returned to v15. I make 1 QSO on ft-8 and try to upload it to LOTW. I get an error message stating that I have my ITU zone set at 3 which is not the case. I am going back to v7 until this gets sorted out,
then I went back to v15
N6VH
Re: LOTW upload
Post by N6VH »
F6EXV wrote: 01 Aug 2021, 17:26 Hi
Paul,
ITU zone is included in LOTW. It can be added in TQSL when setting up your station location. It is also include in LOTW QSLs.
Jim N6VH
