LOTW upload
pa3adu
LOTW upload
Post by pa3adu »
hi,
Installed the new version 2.15.0.0 and since I have problems with the LOTW uploading via the QSL manager. Before this update, the uploading worked fine. I checked the settings in the external services and they look unchanged and the path to my tqsl is correct.
Any suggestions?
73, Nico PA3ADU
Re: LOTW upload
Have you tried a direct tqsl upload?
What error message do you see in QSL manager?
pa3adu
Re: LOTW upload
Post by pa3adu »
have not yet tried a direct upload Terry.
error message in QSL manager:
INFO: ADIF File created successfully.
INFO: TQSL Version 2.5.1
No private TQSL Password set
Executing TQSL with upload
Messages from LOTW:
TQSL Version 2.5.1 [v2.5.1]
Final Status: Command Syntax Error(10)
Command syntax error
LOTW END
the message "No private TQSL Password set" is confusing for me. The manual says that "Not normally used".
I tried a tqsl private password but no luck (different error message)
Re: LOTW upload
Please update Tqsl and try again
pa3adu
Re: LOTW upload
Post by pa3adu »
Not sure what you mean by updating tqsl.
Updating in what (Log4om?) and how.
Or do you suggets to download tqsl from the ARRL site again?
Re: LOTW upload
pa3adu wrote: 11 Jul 2021, 21:31 Not sure what you mean by updating tqsl.
Or do you suggest to download tqsl from the ARRL site again?
You need to open TQSL on your PC and it should say there is an update, follow the instructions.
I did state that on this release a TQSL update is required see-- viewtopic.php?f=1&t=6808
pa3adu
Re: LOTW upload
Post by pa3adu »
That was the trick.
Thanks for the help Terry!
73, Nico PA3ADU
F4HGU
Re: LOTW upload
Post by F4HGU »
Hello Terry,
I had the same issue on my side and had to update TQSL.
Afterwhat I faced to a second issue about the "station location" configuration is TQSL. In fact I was using "French acute accent" in the name of the location. That was working for TQSL in standalone but not thru Log4om.
My location was described as "Domicile Méré" then I changed it to "Domicile Mere" and that was OK. That was not causing any issue with previous Log4om versions.
If it can help other users...
Thank you for the strong support and for this very nice software !!
Patrice
Re: LOTW upload
Latest TQSL now 2.5.8. Please update if you use older versions.
W6SDM
Re: LOTW upload
Post by W6SDM »
I have updated LotW to 2.15.0.0. I've updated TQSL to 2.5.8. I'm having the same problem that I had before. I select the QSOs that I want to upload to LotW, press upload, and the message I get is:
INFO: TQSL Version 2.5.8
And then it hangs. Any help would be very much appreciated.
Steve, W6SDM
