When can we modify an Award
Moderator: OE6CLD
F6FLU
Re: When can we modify an Award
Post by F6FLU »
this is exactly what I did but it does not change anything the RAC award is not registered in the QSO so here it does not change anything when calculating the RAC award ...
Dan - F6FLU
https://F6FLU.org
Did you refresh the award after the QSO updates?
F6FLU
Post by F6FLU »
I just did the tests again, just like you Terry
1) with Update the QSOs are well modified with STATE = AB
State AB.jpg (217.06 KiB) Viewed 3124 times
2) I do "rebuild Stats" and I look at the RAC award and well
I don't have an ALBERTA in my Award table.
I believe that there is something to do that I do not do because the Award table is not updated here
Dan - F6FLU
https://F6FLU.org
Dan,
I've been having issues with my RAC Awards as well, but have not quite spent the time you have debugging so this thread is quite helpful/interesting to me.
How is your column #3 (Reference Group) being filled?
I only have VO1-VO2 noted for Newfoundland-Labrador and can't figure out where that value is coming from. All the other provinces are blank.
I did take the time to manually add the RAC Award ... one QSO at a time. A bit of a PIA. No data in the Comment of Note fields to scan from so am not anxious to wipe and then rescan the RAC award.
F6FLU
Post by F6FLU »
I have the exact same thing ...
We find VO1-VO2 because that's what is by default in the definition of this award :
I think there is a problem with at least this Award but I'm not sure
It wasn't me who made a mistake.
Thank you Nolan for thinking about this Pb.
It's not serious or urgent, I'm just trying to understand how it works, because here in France I am asked this kind of question and I do not know how to answer so I try to do the manipulations to try to understand if this is a problem with me or if it is a problem with log4OM.
Happy New Year Nolan and 73
Dan - F6FLU
https://F6FLU.org
F6FLU
Post by F6FLU »
For information,
if I add the corresponding RAC Award by hand in a QSO, it works, Log4OM takes it into account
It's the relationship between the State (or the comment field) and the RAC Award that doesn't work.
But in view of Terry's explanations, I tested several possibilities.
Normally RAC is a REFERENCE type Award so it takes into account the Comment field and not the State field and in this Comment field we must put the name ALBERTA and not AB; well if I understood. :_)
But I tested these possibilities and it does not change anything.
By comparison if I put AD-01 in the Comment field of a Russian station; Log4OM takes it directly into account as an RDA.
The RDA and RAC Awards are both REFERENCE type ...
to be continued....
Dan - F6FLU
https://F6FLU.org
