Page 2 of 2
Re: WSJT-X log time always 00:00:00
Posted: 28 Apr 2023, 00:19
by ve3wej
times at 00:00:00 are end qso times, what does the start qso time show??? I don't see that
Posted: 29 Apr 2023, 16:05
by ta2bny
Both seem the same.
How can I show you that part that you are asking for not missing anything?
Posted: 26 May 2023, 14:43
if you enable DEBUG MODE in log4om help menu you should be able to see what JT message contains (from program log in help menu) when it's sent to Log4OM...
just send a QSO and check what is contained in the log file, and eventually share that with us
Posted: 20 Jun 2023, 18:10
by ta2bny
Seems like this:
Posted: 12 Jul 2023, 17:52
by ta2bny
The problem finally seems to be solved,
The issue is probably due to the Turkish version of Windows. Thanks to TA9J (Ismail Cakmak), who found that changing the region type to English ( UK) in time and date settings solved the problem. So far Log4OM takes WSJT-X reports correctly and reports to TQSL without an issue.
Posted: 12 Jul 2023, 18:28
by KI5IO
ta2bny wrote: 12 Jul 2023, 17:52
Fahri,
Tnx for the update. Most appreciated.
