Page 2 of 2
Re: Version 2.26.0.0 and Grid Squares
Posted: 23 Jan 2023, 04:07
by VK7XX
for what it's worth, which in fact is a hell of a lot, the info provided above by Nolan, KI5IO is very very important, Thank you heaps Nolan... in particular, the second image... Once those settings are changed, version 2.26.0.0 will once again work correctly. Just why it was changed from version 2.25.0.0. to the current version is anyones guess.. The Main thing tho is that thanks to Nolan, all works correctly now.
(Settings / program config / Software Configuration / Info Providers / Configuration)
Regards
John
VK7XX
Posted: 23 Jan 2023, 13:49
by GM7GAX
Another thanks to Nolan, KI5IO
Posted: 23 Jan 2023, 17:06
by DL4DBM
Thanks Nolan! I had the same problem....
Posted: 24 Jan 2023, 13:54
by DO9KW
I had the same issue allthough I am a XML subscriber on QRZ.com.
My GRID was also shown as the country GRID and not my real locator, that changed back to normal after doing Nolans settings.
In v 2.25.0.0 it was working without changing anything..
I operate a lot of FT8 and the logged GRID from the WSJT-X ADI file is different now from the stored GRID in Log4OM and because of this it also gets uploaded with the wrong Data to the external sources such as LotW, QRZ.com and eQSL.cc
The first Screenshot shows how the QSOs were saved in Log4OM and the second screenshot is an extract from my WSJTX.log (in the adif file the same GRIDs are saved of course)
How can I correct the GRIDs properly in the Log4OM log?
73s
DO9KW - Stefan
