Page 2 of 5
Re: Problem with upload to HRDLOG service
Posted: 24 Mar 2023, 11:00
by sp5ah
G4POP wrote: 24 Mar 2023, 10:57
sp5ah wrote: 24 Mar 2023, 10:56
I'm using 2.25 ....
You need t update to 2.27.1.0 ASAP
I didn't know it was already 2:27. I will check it right away
Posted: 24 Mar 2023, 11:29
by sp5ah
Now even the login functionality on the HRDLOG.NET website does not work
Posted: 24 Mar 2023, 13:36
sp5ah wrote: 24 Mar 2023, 11:29
Then something is wrong in your set up, have you asked HRDLog for a new upload code?
Ft8 or normal ssb loging
As you can see from my earlier post its working fine
Posted: 24 Mar 2023, 14:00
by sp5ah
Login issues resolved.
But unfortunately, using version LOG4OM 2.27.1, upload to HRDLOG.NET still doesn't work, despite using the correct Upload Code....
"upload result [ERROR] qso: Callsign: IM0A Date: 18/03/2023 10:40:15 Band: 10m Mode: USB
HRDLOG END"
Posted: 24 Mar 2023, 14:51
sp5ah wrote: 24 Mar 2023, 14:00
HRDLOG END"
was that with a new upload code?
Try enabling debug or trace mode in the help menu and see if there is more information after another attempted upload
Posted: 24 Mar 2023, 16:13
Help/log level if I recall
Posted: 24 Mar 2023, 16:54
by sp5ah
Take a look at the log snippet. I blurred the UPLOAD CODE
I'm having trouble figuring out what it could be...
My Upload Code is OK.
"2023-03-24 17:29:02.8331 DEBUG: [FwFile][JsonSerializeObject] : JSON Serializing C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:29:02.8331 DEBUG: [FwFile][WriteFile] : Begin writing text file C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:29:02.8331 DEBUG: [FwFile][WriteFile] : Text file write completed C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:29:02.8331 DEBUG: [FwFile][JsonSerializeObject] : Serialization completed C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:29:06.7905 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-03-24 17:29:49.3127 DEBUG: [FwFile][ComposeFilename] : ComposeUserFilename: Returning USER file C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:29:49.3127 DEBUG: [FwFile][JsonDeserializeObject] : Deserializing C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json as L4ONG.BE.LAYOUT.DataGridViewStructure
2023-03-24 17:29:49.3127 DEBUG: [FwFile][LoadFile] : Begin load text file C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:29:49.3127 DEBUG: [FwFile][LoadFile] : Text file load completed C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:29:58.7342 INFO: [dje_zSYYTUD8GZSRMKJ8XVXQBZMYVU4KQ_ejd] : Massive upload of 1 on HRDLOG
2023-03-24 17:30:00.5653 INFO: [dje_zNR59ZFMSE76UKA8RVFEFQ8A973K78NVVKX_ejd] : [HRDLOG UPLOAD LOG] uploading LOG with 1 QSO
2023-03-24 17:30:00.5653 INFO: [dje_zJ6S8N7M4EZ6H9L5G84AECX8NUVJAHRAHKX_ejd] : [HRDLOG UPLOAD] Uploading QSO on HRDLOG: CT2GSN|19.03.2023 17:53:57|10m|USB
2023-03-24 17:30:00.5653 INFO: [dje_zJ6S8N7M4EZ6H9L5G84AECX8NUVJAHRAHKX_ejd] : [HRDLOG UPLOAD] Updating existing QSO on HRDLOG: CT2GSN|19.03.2023 17:53:57|10m|USB
2023-03-24 17:30:00.5653 INFO: [AdifManagement] : Begin export single QSO to ADIF string
2023-03-24 17:30:00.5653 INFO: [AdifManagement] : Export QSO to ADIF file completed
2023-03-24 17:30:00.5653 DEBUG: [dje_zJ6S8N7M4EZ6H9L5G84AECX8NUVJAHRAHKX_ejd][MoveNext] : [HRDLOG UPLOAD - UPDATE] payload:
CALLSIGN=SP5AH CMD=UPDATE ADIFKEY=<CALL:6>CT2GSN<QSO_DATE:8:D>20230319<TIME_ON:6>175357<EOR> CODE=XXXXXXXXXX APP=LOG4OM2 ADIFDATA=<CALL:6>CT2GSN <BAND:3>10M <MODE:3>SSB <QSO_DATE:8>20230319 <TIME_ON:6>175357 <DISTANCE:7>2517.89 <DXCC:3>272 <EQSL_QSL_RCVD:1>R <EQSL_QSL_SENT:1>Y <FREQ:9>28.450000 <GRIDSQUARE:6>IN51QM <LOTW_QSL_RCVD:1>R <LOTW_QSL_SENT:1>Y <SUBMODE:3>USB <STATION_CALLSIGN:5>SP5AH <QSL_RCVD:1>N <QSL_SENT:1>N <QSL_SENT_VIA:1>E <RST_RCVD:2>58 <RST_SENT:2>58 <EOR>
2023-03-24 17:30:00.5809 INFO: [dje_z37BXMBCLY4GPD83KQ22JD_ejd] : PostDataAsync: Posting data to http://robot.hrdlog.net/NewEntry.aspx. upload information:
2023-03-24 17:30:01.0264 DEBUG: * [dje_z37BXMBCLY4GPD83KQ22JD_ejd][MoveNext][445 ms] : PostDataAsync: Post completed
<?xml version="1.0" ?>
<HrdLog xmlns="http://xml.hrdlog.com">
<NewEntry>
<error>Unable to find QSO</error></NewEntry>
</HrdLog>
2023-03-24 17:30:01.0264 DEBUG: [dje_zJ6S8N7M4EZ6H9L5G84AECX8NUVJAHRAHKX_ejd][MoveNext] : [HRDLOG UPLOAD - UPDATE] result:
<NewEntry>
</HrdLog>
2023-03-24 17:30:01.0264 DEBUG: [UCAdvancedListbox][AddRow] : [MESSAGE ON LISTBOX Upload Confirmations] upload result [ERROR] qso: Callsign: CT2GSN Date: 19.03.2023 17:53:57 Band: 10m Mode: USB
2023-03-24 17:30:01.0264 WARN: [dje_zJ6S8N7M4EZ6H9L5G84AECX8NUVJAHRAHKX_ejd][MoveNext] : [HRDLOG UPLOAD] update result [ERROR]
2023-03-24 17:30:01.0264 WARN: [dje_zJ6S8N7M4EZ6H9L5G84AECX8NUVJAHRAHKX_ejd][MoveNext] : [HRDLOG UPLOAD - UPDATE] payload:
2023-03-24 17:30:01.0419 INFO: * [dje_zJ6S8N7M4EZ6H9L5G84AECX8NUVJAHRAHKX_ejd][476 ms] : [HRDLOG UPLOAD] ###### END ######
2023-03-24 17:30:01.0419 INFO: * [dje_zNR59ZFMSE76UKA8RVFEFQ8A973K78NVVKX_ejd][476 ms] : [HRDLOG UPLOAD LOG] ###### END ######
2023-03-24 17:30:01.0419 DEBUG: [UCAdvancedListbox][AddRow] : [MESSAGE ON LISTBOX Upload Confirmations] HRDLOG END
2023-03-24 17:30:05.3306 DEBUG: [FwFile][JsonSerializeObject] : JSON Serializing C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:30:05.3306 DEBUG: [FwFile][WriteFile] : Begin writing text file C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:30:05.3306 DEBUG: [FwFile][WriteFile] : Text file write completed C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:30:05.3451 DEBUG: [FwFile][JsonSerializeObject] : Serialization completed C:\Users\pluty\AppData\Roaming\Log4OM2\user\layout_datagrid_ManageConfirmation_user.json
2023-03-24 17:30:06.9104 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
Posted: 24 Mar 2023, 17:52
by Iw7dol
G4POP wrote: 24 Mar 2023, 09:39
Iw7dol wrote: 24 Mar 2023, 09:07
The upload with HRDLOG was working until the last release: on 2.27 it doesn't work!
My guess is that you are using FT8 and have not followed the instructions here
viewtopic.php?t=8260
Because I just auto uploaded two QSO's to HRDLog without issues, see below
I followed the instructions of the new functions that complicate life. I also had to change the recommended ports because they were wrong. However, the upload doesn't work. Can you show me your settings?
I use JTDX+JT-Alert or WSJT-X only.
Posted: 24 Mar 2023, 18:15
by KD0ZV
The ports are not recommended ports. They are specific to the apps on YOUR system. So check your 3rd party apps and configure the ports in Log4OM to match your other apps.
Posted: 25 Mar 2023, 15:11
by sp5ah
Problem still exists
