Page 2 of 2
Re: UPDATE_CQ_ITUZONE
Posted: 30 Jun 2023, 22:56
by wb2bin
Nolan,
That is what I sent. I only have one inbound UDP connection showing but when I hoover over the message it shows the parameters that you have. Do you get the message when you download from LOTW that say updating CQ ITU Zones. If that is the way it's supposed to be but it can be annoying.
Greg
Posted: 30 Jun 2023, 23:13
by wb2bin
I think I have found something. If I select the msg and then click update then the parameters appear and I can uncheck. I will try that.
Posted: 01 Jul 2023, 00:31
by KI5IO
Greg,
I've never had any update banners / warnings when doing a d/l for my LOTW Q;s.
Is that an alarm that appears in the area just to the left of the "Notes" field inside of an icon?
Posted: 01 Jul 2023, 06:19
Greg,
You must have selected the option in the UDP connection, if you dont want zones updated just de-select it!
I still cannot understand where you refer to the "UPDATE_CQ_ITUZONE" message apearing?
The self care information is a thing you only need to look at if you have an issue, not something you need to regularly refer to!
Posted: 01 Jul 2023, 09:58
by wb2bin
I thought I had already sent this but I don't see it so if this is a double I' sorry.
I found it. I highlighted the message and did an edit and those parameters came up and could be edited.
Thanks very much for the help.
Greg
