WAS-TRIPLE tag not found
w9mdb
Re: WAS-TRIPLE tag not found
Post by w9mdb »
Not sure your point....I was just requesting that all the other WAS awards be added and provided you the data file to do it.
Meanwhile I have it working locally.
w9mdb wrote: 10 Sep 2023, 15:50 Not sure your point....I was just requesting that all the other WAS awards be added and provided you the data file to do it.
The point was that while users are waiting for us to do another release, that you might be generous and provide everyone with a file that even those not so well versed in computers as your goodself could use by providing an XML file for them to easily import.
Final comment
w9mdb
Post by w9mdb »
Ahhh...can do....
This is a drop-in replacement for
C:\Users\[username]\AppData\Roaming\Log4OM2\Activations.SQLITE
https://www.dropbox.com/scl/fi/gwxqq9di ... 65xzr&dl=0
Mike,
Can you pls export the file via Award Manager as an XML?
I have a number of local OMs who would love to import an XML that you have modified.
They don't want to be messing with sql files.
w9mdb
Post by w9mdb »
Here it is
WAS20230910.xml
(84.9 KiB) Downloaded 134 times
w9mdb wrote: 10 Sep 2023, 16:51Here it is
Mike,
Tnx much. Most appreciated.
w9mdb wrote: 09 Sep 2023, 15:37 Also WAS-5B is missing too.
Mike,
I'm not finding WAS-5B in the XML you posted.
w9mdb
Post by w9mdb »
Try downloading again...I had put it in my friend's system and the missed it when expanding my own.
w9mdb wrote: 10 Sep 2023, 20:38 Try downloading again...I had put it in my friend's system and the missed it when expanding my own.
Mike,
The XML file you had attached in the post or two above? You replaced it with an updated one?
w9mdb
Post by w9mdb »
Arrghhh...was thinking it was a dropbox link.....
WAS20230910.xml
(85.57 KiB) Downloaded 141 times
