Using 2.28.0.8
Was helping another user set up Log4OM and saw this.
TAGS NOT FOUND IN AWARDS: APP_LOTW_CREDIT_GRANTED:WAS-TRIPLE (WAS-TRIPLE)
WAS-TRIPLE tag not found
Re: WAS-TRIPLE tag not found
It is in the LOTW download log for him.
Where does Log4OMV2 put the downloaded files? I can't seem to find them...
I added the WAS-TRIPLE to the WAS Award configuration and downloaded his LOTW again and they got tagged as granted correctly?
So easy fix...you may want to add that to the WAS award.
Also WAS-5B is missing too.
Actually I see a bunch of the LOTW WAS awards missing....
So I added them all...
Here's an updated sql file
https://www.dropbox.com/scl/fi/lnptuj2v ... vulv4&dl=0
Much easier for everyone if you export the award from the award manager file menu as a normal .xml filew9mdb wrote: 09 Sep 2023, 20:13 Actually I see a bunch of the LOTW WAS awards missing....
sqlite3 <activations.sql
Will create the database
Not all of our users are competent enough to do that, in fact very few of them! But never mind Eh!
Well I was assuming you guys would just put the new information in the next release.
And meanwhile?w9mdb wrote: 10 Sep 2023, 13:57 Well I was assuming you guys would just put the new information in the next release.
