Can LOG4OM use 2 LOTW certificates?
Re: Can LOG4OM use 2 LOTW certificates?
QSO Manager
Filters (Its at bottom of window)
Standard fields tab
Select Station call sign in left hand field menu
'Equal' in centre field menu
Enter the call in the right hand field
Click 'Plus' sign
Close filter window and you should see the QSO's recorded with that Station call sign
If unsuccessful substitute Operator and Owner callsign instead of Station call and repeat
WA2SQQ
Post by WA2SQQ »
That found it - Thanks
