Thanks Lele for your response. Understand perfectly on that.
I will try the Beta version.
Thanks to eveyone.
Refresh Data (World Globe) Edit QSO changes ITU & CQ zones incorrectly.
Re: Refresh Data (World Globe) Edit QSO changes ITU & CQ zones incorrectly.
Ken,KS4VOL wrote: 11 Mar 2024, 10:55 Thanks Lele for your response. Understand perfectly on that.
Thanks to eveyone.
Download/install the Alpha version that Lele provided the links for in the post above.
I think you will find the grid / cq/ itu issues far different in that Alpha release.
Just wanted to update.
Log4OM update 2.32.1.0 fixed the problem. Thank you Lele IW3HMH for the fast response. It updated just fine the 30 ish QSO's from FT8 without names and QTH didn't changing anything in the ITU & CQ zones. The two that did they had errors in QRZ and that you can't control. HIHI I verified the two errors at https://zone-check.eu/.
Thanks again Lele
Thanks again Lele
I lost a power supply and no backup so I had to get it shipped so wasn't in the shack for awhile. Thanks Nolan for the info and help.
Everybody that has responded really helped in the problem. 73's until next problem.
I'm back. The Refresh Data (World Globe) to update QSO now will not update with contacts Name and QTH and possible anything else. Did you deactivate it? I stopped using it when LOTW went down as that seemed like the time it stopped functioning. When LOTW came back online I tried it still nothing. Then I waited till the new update to Log4OM which is 2.33.0.0, well still doesn't work when you click on Refresh Data. I have not changed a thing unless it was by accident and I don't remember playing around in Program Configuration. One reason was all the trouble in the past.
Thank you in advance you all are the best love Log4OM
