Page 2 of 3
Re: HELP !!!!!!!
Posted: 29 Aug 2024, 19:20
by ZB3Z
i dont think my JTDX actually logs to LOTW or eQSL if it does where ?
Re: HELP !!!!!!!
Posted: 29 Aug 2024, 20:17
by ZB3Z
ok Terry when i put in sent ...... Yes it comes back with 32 searches
Re: HELP !!!!!!!
Posted: 30 Aug 2024, 07:33
You really need to watch the videos and read the user guide but here is a step by step of how to update the confirmation status - follow the RED numbers in order
You could also do 'Requested' if that is what your config is set to.
Same proceedure for LOTW and other external services
QSL Manager.png (82.64 KiB) Viewed 3942 times
Re: HELP !!!!!!!
Posted: 30 Aug 2024, 07:48
by ZB3Z
Will do that Terry later on as I have a busy day today and thank you for your help and assistance so once they have been loaded to either lotw or eQSL they do not need to be loaded again
Re: HELP !!!!!!!
Posted: 30 Aug 2024, 08:14
ZB3Z wrote: 30 Aug 2024, 07:48 Will do that Terry later on as I have a busy day today and thank you for your help and assistance so once they have been loaded to either lotw or eQSL they do not need to be loaded again
If they can be seen at lotw or eqsl web site why would you? No!
Re: HELP !!!!!!!
Posted: 30 Aug 2024, 13:38
ZB3Z wrote: 29 Aug 2024, 19:20 i dont think my JTDX actually logs to LOTW or eQSL if it does where ?
Well it definitely uploads to eqsl, see the jtdx user guide re reporting, it may also load to lotw don't use it so can't comment
Re: HELP !!!!!!!
Posted: 02 Sep 2024, 08:05
by ZB3Z
Ok Terry I did all what you said and it now works except on the log book I have eqsl sent and Eqsl received plus lotw sent and lotw received i now have to do the received manually , am I missing something there or should it be automatticslly
Re: HELP !!!!!!!
Posted: 02 Sep 2024, 09:15
ZB3Z wrote: 02 Sep 2024, 08:05 Ok Terry I did all what you said and it now works except on the log book I have eqsl sent and Eqsl received plus lotw sent and lotw received i now have to do the received manually , am I missing something there or should it be automatticslly
This is all in the user guide but just to conclude this lengthy thread!
Ensure the boxes with the red outline around them are checked
Ignore the port numbers and other data they were just used to create graphics for this post
DONT FORGET TO CLICK THE 'SAVE' BUTTON IN ALL CASES
Untitled 2.png (46.15 KiB) Viewed 2967 times
Untitled 3.png (16.16 KiB) Viewed 2967 times
Re: HELP !!!!!!!
Posted: 02 Sep 2024, 15:35
by ZB3Z
checked what you suggested Terry it is sending them( but not receiving well not on my end) I have closed all the programs this is the only thing i have open is this so as i had the QSO at they started at 14:57 ( just to try ) so i have gave it enough time for eQSL & LOTW wouldnt you say
Re: HELP !!!!!!!
Posted: 02 Sep 2024, 15:43
by ZB3Z
oops so sorry forgot this QSO on eQSL
