Without QRZ xml you'll get an error message on every decode.
You may as well just wait for a new version where you can turn it off.
Cluster utility
Re: Cluster utility
Working with host 127.0.0.1 now. No idea what was going on before.
Getting some other error messages but was unable to capture them. Will keep an eye if it shows up again.
Re: Cluster utility
w9mdb wrote: 16 Jan 2025, 05:27 Without QRZ xml you'll get an error message on every decode.
OK, will do.
Thank you very much for your prompt replies!
Re: Cluster utility
I took a look at this and QRZ is very embedded in the program so I'm not going to be able to make it work without the XML lookups.
Sorry....
Sorry....
Re: Cluster utility
Fully understand. Thank you for looking into it.w9mdb wrote: 16 Jan 2025, 14:25 I took a look at this and QRZ is very embedded in the program so I'm not going to be able to make it work without the XML lookups.
Sorry....
Vince
Re: Cluster utility
.NET runtime installed and updated, but I receive this error
Windows 11 Pro 24H2
Windows 11 Pro 24H2
Mishel, Z31PM
Mishel, Z31PM
Re: Cluster utility
Should have installed .Net 9
Re: Cluster utility
I've had problems before installing .Net which took several reboots and installs before it finally worked.
