Page 2 of 3
Re: Cluster utility
Posted: 16 Jan 2025, 05:27
by w9mdb
Without QRZ xml you'll get an error message on every decode.
You may as well just wait for a new version where you can turn it off.
Re: Cluster utility
Posted: 16 Jan 2025, 05:28
by va3vf
Working with host 127.0.0.1 now. No idea what was going on before.
Getting some other error messages but was unable to capture them. Will keep an eye if it shows up again.
Re: Cluster utility
Posted: 16 Jan 2025, 05:29
by va3vf
w9mdb wrote: 16 Jan 2025, 05:27
OK, will do.
Thank you very much for your prompt replies!
Re: Cluster utility
Posted: 16 Jan 2025, 14:25
by w9mdb
I took a look at this and QRZ is very embedded in the program so I'm not going to be able to make it work without the XML lookups.
Sorry....
Re: Cluster utility
Posted: 16 Jan 2025, 18:36
by va3vf
w9mdb wrote: 16 Jan 2025, 14:25
Sorry....
Fully understand. Thank you for looking into it.
Vince
Re: Cluster utility
Posted: 18 Jan 2025, 14:08
va3vf wrote: 16 Jan 2025, 18:36
Sorry....
Vince
Re: Cluster utility
Posted: 18 Jan 2025, 19:24
by Z31PM
.NET runtime installed and updated, but I receive this error
- Untitled-1.jpg (13.45 KiB) Viewed 1553 times
Windows 11 Pro 24H2
Re: Cluster utility
Posted: 18 Jan 2025, 20:56
by w9mdb
Should have installed .Net 9
Re: Cluster utility
Posted: 18 Jan 2025, 22:09
by Z31PM
I did. V. 9.0.1 x64
Re: Cluster utility
Posted: 18 Jan 2025, 22:38
by w9mdb
I've had problems before installing .Net which took several reboots and installs before it finally worked.
