New Version lost setup
K0AY
Re: New Version lost setup
Post by K0AY »
Terry...
Yes I uninstalled the earlier version of 1.19, then I uploaded what I think is the newer version (It had the same #). If the newer version is looking for the latest config.exe, then it will pick up the one I made in filling in the blanks which would be wrong. As I said before, I also used older ones from 1.18. Everything works except exporting LOTW and LOTW is up and running.
Art
OK Art, so if I understand you correctly everything is now working in Log4om except LOTW?
Please enable debug mode in the Log4om help menu
Attempt to upload to LOTW from Log4om
Then complete the support request in the help menu - note where the zipped support request file is saved to
Send me the zipped file created by the support request by email to g4pop (at) arrl.net
Do not post the file on the forum because it will contain sensitive information
Art's issue is resolved he had the station ID for LOTW entered incorrectly, one he corrected this the upload worked fine.
KH6CT
ALL WORKING FINE HERE
Post by KH6CT »
:D
Uninstalled the old and installed the new. Renamed xxxxxxxxxxx_config.xml and pasted it into the new installation; worked just great. Restarted and everything was there... new features and all the old data. Thanks for continuing the good work.
Best 73, Steve, KH6CT/W4
