Page 3 of 4
Re: DXCC Most Wanted Rank
Posted: 27 Jun 2014, 18:29
K0HB wrote:I haven't seen your email response to my log.
This is what I sent by email and this was forwarded to you again just now
Hans,
The download
2014-06-24 18:42:05.5161 INFO: Log4OMMainWindow: *Open IMPORT CLUBLOG FROM WEB*
2014-06-24 18:42:05.5231 INFO: FileManagement: Clublog begin download
2014-06-24 18:42:05.5231 DEBUG: FileManagement: URL https://secure.clublog.org/cty.php?api= ... ce4c6bbe0e
2014-06-24 18:42:08.1963 INFO: FileManagement: Clublog begin save database
2014-06-24 18:42:08.3843 INFO: FileManagement: Clublog save database completed
contains all three files
So when you go to your roaming/logom folder the single file has been interpreted into three xml files called Clublog.xml, cty.xml & ranking.xml
I have just done a manual update and all three files have the same date/time stamp, please check the corresponding files in your roaming/logom folder! Because the update is working OK according to your log file.
73 Terry
Posted: 27 Jun 2014, 19:04
by NN7D
I have the same issue. US stations are ranked 11 in the DX Spots (F2) and Cluster (F9) screens. Have gone to Settings, Clublog Database, Load Clublog Database and it reports success. Have shutdown Log4OM, (actually uninstalled and installed newer version) and restarted, same rank for US of 11.
I'll look into the files.
Doug
W7DRM
Posted: 27 Jun 2014, 19:11
Doug,
There was an issue at Clublog but Michael fixed it on Tuesday.
I have just done another Clublog update and the rankings are all as I would expect so I will be interested in your results
Posted: 27 Jun 2014, 19:34
by NN7D
Here is my log entry for the Clublog update which I performed above:
2014-06-27 12:01:48.6797 INFO: Log4OMMainWindow: *Open IMPORT CLUBLOG FROM WEB*
2014-06-27 12:01:48.6797 INFO: FileManagement: Clublog begin download
2014-06-27 12:01:48.6797 DEBUG: FileManagement: URL https://secure.clublog.org/cty.php?api= ... ce4c6bbe0e
2014-06-27 12:01:52.3306 INFO: FileManagement: Clublog begin save database
2014-06-27 12:01:52.5490 INFO: FileManagement: Clublog save database completed
Ok, after the above update, I have the following files/dates/times:
Clublog.xml 6/27/2014 12:01
Cty.xml 6/27/2014 12:01
Ranking.xml 6/22/2014 11:57 (note, older date)
In the Ranking .xml file it contains this element:
<MostWantedRank>
<Emission>UNDEFINED</Emission>
<Dxcc>291</Dxcc>
<Ranking>11</Ranking>
</MostWantedRank>
It seems like the Clublog Update is not updating the Ranking.xml file.
BTW, Yesterday I updated Log4OM to the newest Beta version.
Hope this make sense.
Doug
W7DRM
Posted: 27 Jun 2014, 19:47
by ik2egl
I noticed that when doing setting --> clublog database --> load clublog database the messsagebox appears really suddenly no time required ?)
while in all the others settings it takes a while .
Posted: 27 Jun 2014, 19:50
Doug,
Close Log4om, delete the ranking file, restart Log4om and update Clublog
Report what happens please
Posted: 27 Jun 2014, 20:06
by K0HB
I've just now done a manual update, and the results are the same. ranking.xml is NOT updated
As with W7DRM, the timestamps of clublog.xml and cty.xml are fresh and identical, but the time stamp of ranking.xml is from several days back.
I am running version 1.17.1.0.
(As I mentioned earlier, I can get a ranking.xml update if I delete the existing version)
Posted: 27 Jun 2014, 20:38
by NN7D
G4POP wrote:Doug,
I closed Log4OM, renamed the Ranking.xml file, then reopened Log4OM and as expected, a new Ranking.xml file was created with current date/time, and the cluster window now shows USA as Rank 340. This is the same behavior as reported by Hans.
But shouldn't the Clublog update renew the Ranking.xml file automatically? Seems like there is a bug in the update process.
Thanks,
Doug
Posted: 28 Jun 2014, 05:55
Well I think that we need Daniele's input on this, because I cannot understand what's happening.
The only reason that I can think of is that perhaps if there is no change to "Rankings" in the Clublog download file then perhaps the ranking.xml file is not updated but I don't know if that is what happens - Daniele please comment
Posted: 28 Jun 2014, 08:06
by DF5WW
Meanwhile my test spotting showing rank 340 for the USA ..... I´ve done nothing, only updated Clublog via L4O menu ... I´ve not deleted the ranking.xml ... However, it works here :!: :!:
Using Windows 7 Ultimate 64 Bit here :!:
