V2 - no spot in Cluster (F8)
N4IAG
Re: V2 - no spot in Cluster (F8)
Post by N4IAG »
HB9VQQ wrote: 30 Jan 2020, 18:46 What's your "View" setting look like ?
The view settings are the same 'worked'. The best I can tell, everything is identical, but the external cluster gets more spots than the main one for some reason. Maybe I've done something stupid. I'll play around with it later.
HB9VQQ
Post by HB9VQQ »
I am having both windows open, can't see a difference with View set to "LOTW". When I change the View to "Worked" I can duplicate your observation.
Correction, after some clicking I am getting the identical results in both Windows when View is set to "Worked" .... a bit strange behaviour though.
Flex 6600 - Spiderbeam
IK0TIX
Post by IK0TIX »
N4IAG wrote: 30 Jan 2020, 19:14
just as a test use my same settings:
Max IK0TIX
N4IAG
Post by N4IAG »
IK0TIX wrote: 30 Jan 2020, 22:00
With those settings I see some old spots in the external window, with no new spots appearing, and the F8 cluster window is still empty.
I then connected to some random servers with the default settings, and that works fine in the detachable window, spots are buzzing in, but still no joy in the F8 window, just a few sporadic spots show. Things are getting worse. I'll play with it some more tomorrow.
IK0TIX
Post by IK0TIX »
my settings delete FT8 / FT4.
If you want to see FT8 / FT4 delete the lines set / noft8 and set / noft4 also change in the first line from SH / MYDX 30 to SH / DX 30
Max IK0TIX
N4IAG
Post by N4IAG »
IK0TIX wrote: 31 Jan 2020, 13:11 my settings delete FT8 / FT4.
My problem was not so much with the cluster working, but with it showing properly in the F8 tab. Anyway, I reset the filters again and toggled the Super Cluster on & off a few times, then it began working.
So far the the F8 cluster is now matching the other cluster window, spot for spot. If it stays like this I’m a happy ham! Thanks for all of the advise from everyone. This is a great program!
