LoTW uploads have stopped working - v2.36.1.0
G0TRT
Post by G0TRT »
Since the upgrade to v2.36.1.0 LoTW uploads have stopped working.
When Log4OM is closed the shutdown hangs (forever) whilst the LoTW upload tried to take place; when I try and push the uploads manually Log4OM just stits there trying to upload through TQSL.
All advice and fault finding suggestions welcome :)
Re: LoTW uploads have stopped working - v2.36.1.0
Has your TQSL Cert expired?
G0TRT
Post by G0TRT »
Thanks Terry,
No, my certificate is in date.
When I try a manual upload of some 417 QSO's the Upload Confirmations window stalls at:
INFO: ADIF File created successfully.
INFO: TQSL Version 2.8.1
No private TQSL Password set
Executing TQSL with upload
MANAGED MODE SET
73, Ciemon
Certainly something wrong with your set up because it works fine for me as confirmed below
MANAGED MODE SET
Messages from LOTW:
TQSL Version 2.8.1 [v2.8.1]
Signing using Callsign G4POP, DXCC Entity ENGLAND
Attempting to upload one QSO
D:\Google Drive\G4POP Log4OM NG\config\LOTW\LOTW_UPLOAD_20250613191114.adi: Log uploaded successfully with result:
File queued for processing
After reading this message, you may close this program.
Final Status: Success(0)
success; log signed and uploaded and accepted without incident
INFO: SAVING LOG...
INFO: LOG SAVED
LOTW END
Check the firewall and anti virus are not intervening or perhaps something set wrong in TQSL
When did it stop working - Precicely?
