I have been running Log4OM 1.6 and I just downloaded and installed Log4OM 1.18.0 and received the notice that my MySQL database needs upgrading. I found a link to the script (http://www.pisto.it/LogOm/mysql1171.zip) but how do I run the script?
MySQL reports that all components are up-to-date.
Ron W5RKN
How do I upgrade MySQL database?
Re: How do I upgrade MySQL database?
Hi Ron, script must be executed from MySQL db manager.
If you're not skilled with DB management under MySQL my suggestion is to get the latest backup automatically made by Log4OM and then re-create a new database with new release, re-importing your ADIF
MySQL is a little bit more complex to run from Log4OM itself, because you must use ROOT permissions, these are not saved by Log4OM so you should open mysql management window and run the script with root permissions.w5rkn wrote:I have been running Log4OM 1.6 and I just downloaded and installed Log4OM 1.18.0 and received the notice that my MySQL database needs upgrading. I found a link to the script (http://www.pisto.it/LogOm/mysql1171.zip) but how do I run the script?
Ron W5RKN
