Russia Award
Moderator: OE6CLD
OE6CLD
Russia Award
Post by OE6CLD »
Hi all,
Please find attached the award definition for the RUSSIA - Russia award. If you're still using Log4OM < v1.18 manually copy the attached xml file (it should be named award_RUSSIA.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM.
Starting with version 1.18.0 Log4OM will update all awards automatically, there is no need to copy the awards file to a specific folder. We really would recommend to update to this or any newer version!
More information regarding the award can be found here: http://www.srr.ru/AWARD/russia_eng.php
Claus, EI7JZ/OE6CLD
award_RUSSIA.xml
Russia Award
(61.16 KiB) Downloaded 639 times
Russia Award.jpg (76 KiB) Viewed 4347 times
Claus, OE6CLD/DJ0DX/EI7JZ
