Hi, I seem to have a problem - when I log a QSO with SOTA ref. of my contact, sometimes during an edit of other data in the QSO, the SOTA ref. previously inserted disappears. I noticed this either during QSO first logging, now also it is evident when re-editing a QSO - any random field, or no real changes, but clicking "SAVE" during edit.
I installed the portable version of latest release, but previously I also noticed this in version 17.
Is this a common problem? Does it have any reason I could fix in a configuration? Many thanks in advance for any help...
SOTA problem - disappearing SOTA ref.
Moderator: OE6CLD
Re: SOTA problem - disappearing SOTA ref.
Yes I also see the same problem, if I edit an existing SOTA contact and save it the SOTA reference vanishes.
Ian VK1DI
Ian VK1DI
I thought we fixed this in version 1.18.1 is that the version you are using?
I am seeing the same behavior with the portable release of version 1.18.1 here as well.
---73 Karl KA3RCS
The problem seems to have appeared after upgrading to v 1.18.1. Did not notice this in v 1.18.0. You do not even need to save, just edit any SOTA QSO and have a look at the IOTA/SOTA Tab. The SOTA reference is removed.
Added to Mantis - The previous issue was only when using Mysql
