ERROR MESSAGE
Moderator: DF5WW
OE5CCN
ERROR MESSAGE
Post by OE5CCN »
Habe in letzter Zeit immer dieses Problem! Wer kann helfen oder genügt es einfach die Meldung zu ignorieren?
Code: Select all
Unhandled exception has occurred in your application.If you click Continue the application will
ignore this error and attempt to continue.If you click Quit,the application will close
immediately.Collection was modified,enumeration operation may not execute.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: Collection was modified; enumeration operation may not
execute.
   at System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource)
   at System.Collections.Generic.List`1.Enumerator.MoveNextRare()
   at System.Collections.Generic.List`1.Enumerator.MoveNext()
   at ClusterViewControl.SmallListView.UpdateList()
   at ClusterViewControl.SmallListView.cbCW_CheckedChanged(Object sender, EventArgs e)
   at System.Windows.Forms.CheckBox.OnCheckedChanged(EventArgs e)
   at System.Windows.Forms.CheckBox.set_CheckState(CheckState value)
   at System.Windows.Forms.CheckBox.OnClick(EventArgs e)
   at System.Windows.Forms.CheckBox.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr
lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.34014 built by: FX45W81RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
LogOMUI
    Assembly Version: 1.18.0.0
    Win32 Version: 1.18.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOMUI.exe
System
    Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System
.dll
    Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561
934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3
a/System.Drawing.dll
System.Configuration
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f1
1d50a3a/System.Configuration.dll
System.Core
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/S
ystem.Core.dll
System.Xml
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/Sy
stem.Xml.dll
LogOM.BE
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.BE.DLL
RSTControl
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/RSTControl.DLL
SOTAControl
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/SOTAControl.DLL
DXCCControl
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/DXCCControl.DLL
IOTAControl
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/IOTAControl.DLL
LocationsControl
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LocationsControl.DLL
DataGridViewCustom
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/DataGridViewCustom.DLL
StatisticControl
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/StatisticControl.DLL
ClusterViewControl
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/ClusterViewControl.DLL
DigitalDisplayControl
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/DigitalDisplayControl.DLL
EXListView
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/EXListView.DLL
LogOM.Storage
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.Storage.DLL
LogOM.Common
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.Common.DLL
System.Runtime.Serialization
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b
77a5c561934e089/System.Runtime.Serialization.dll
LogOM.BL
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.BL.DLL
NLog
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/NLog.DLL
Microsoft.GeneratedCode
    Assembly Version: 1.0.0.0
    CodeBase:
stem.Xml.dll
System.ServiceModel
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c5619
34e089/System.ServiceModel.dll
System.Data
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/Sys
tem.Data.dll
LogOM.WCF
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.WCF.DLL
LogOM.TCPServer
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.TCPServer.DLL
    CodeBase:
stem.Xml.dll
    CodeBase:
stem.Xml.dll
Nito.Async.Sockets
    Assembly Version: 1.4.0.0
    Win32 Version: 1.4.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/Nito.Async.Sockets.DLL
System.Data.SQLite
    Assembly Version: 1.0.77.0
    Win32 Version: 1.0.77.0
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/System.Data.SQLite.DLL
System.Transactions
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934
e089/System.Transactions.dll
System.EnterpriseServices
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f
7f11d50a3a/System.EnterpriseServices.dll
    CodeBase:
stem.Xml.dll
    CodeBase:
stem.Xml.dll
    CodeBase:
stem.Xml.dll
    CodeBase:
stem.Xml.dll
    CodeBase:
stem.Xml.dll
    CodeBase:
stem.Xml.dll
Accessibility
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a
/Accessibility.dll
Log4Om.Shared
    CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/Log4Om.Shared.DLL
System.Numerics
    CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e0
89/System.Numerics.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Irgendwie schickt LOG4OM auch keine Daten mehr zu LOTW obwohl die Einstellungen sonst in in der früheren Version funktioniert hatten.Beste 73 de OE5CCN
OE5CCN
OM: Christian
Salzkammergut /OÖ.
Austria
Re: ERROR MESSAGE
Thank you for reporting. I will check the exception.
If our moderator can kindly send me a description of your actions to reproduce issue i will be grateful
Daniele IW3HMH
