ERROR MESSAGE
Posted: 06 Sep 2014, 17:34
Habe in letzter Zeit immer dieses Problem! Wer kann helfen oder genügt es einfach die Meldung zu ignorieren?
Irgendwie schickt LOG4OM auch keine Daten mehr zu LOTW obwohl die Einstellungen sonst in in der früheren Version funktioniert hatten.Beste 73 de OE5CCN
Code: Select all
Unhandled exception has occurred in your application.If you click Continue the application will
ignore this error and attempt to continue.If you click Quit,the application will close
immediately.Collection was modified,enumeration operation may not execute.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: Collection was modified; enumeration operation may not
execute.
at System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource)
at System.Collections.Generic.List`1.Enumerator.MoveNextRare()
at System.Collections.Generic.List`1.Enumerator.MoveNext()
at ClusterViewControl.SmallListView.UpdateList()
at ClusterViewControl.SmallListView.cbCW_CheckedChanged(Object sender, EventArgs e)
at System.Windows.Forms.CheckBox.OnCheckedChanged(EventArgs e)
at System.Windows.Forms.CheckBox.set_CheckState(CheckState value)
at System.Windows.Forms.CheckBox.OnClick(EventArgs e)
at System.Windows.Forms.CheckBox.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr
lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34014 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
LogOMUI
Assembly Version: 1.18.0.0
Win32 Version: 1.18.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOMUI.exe
System
Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System
.dll
Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561
934e089/System.Windows.Forms.dll
System.Drawing
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3
a/System.Drawing.dll
System.Configuration
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f1
1d50a3a/System.Configuration.dll
System.Core
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/S
ystem.Core.dll
System.Xml
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/Sy
stem.Xml.dll
LogOM.BE
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.BE.DLL
RSTControl
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/RSTControl.DLL
SOTAControl
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/SOTAControl.DLL
DXCCControl
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/DXCCControl.DLL
IOTAControl
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/IOTAControl.DLL
LocationsControl
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LocationsControl.DLL
DataGridViewCustom
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/DataGridViewCustom.DLL
StatisticControl
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/StatisticControl.DLL
ClusterViewControl
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/ClusterViewControl.DLL
DigitalDisplayControl
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/DigitalDisplayControl.DLL
EXListView
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/EXListView.DLL
LogOM.Storage
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.Storage.DLL
LogOM.Common
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.Common.DLL
System.Runtime.Serialization
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b
77a5c561934e089/System.Runtime.Serialization.dll
LogOM.BL
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.BL.DLL
NLog
Assembly Version: 2.0.0.0
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/NLog.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
CodeBase:
stem.Xml.dll
System.ServiceModel
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c5619
34e089/System.ServiceModel.dll
System.Data
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/Sys
tem.Data.dll
LogOM.WCF
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.WCF.DLL
LogOM.TCPServer
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/LogOM.TCPServer.DLL
CodeBase:
stem.Xml.dll
CodeBase:
stem.Xml.dll
Nito.Async.Sockets
Assembly Version: 1.4.0.0
Win32 Version: 1.4.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/Nito.Async.Sockets.DLL
System.Data.SQLite
Assembly Version: 1.0.77.0
Win32 Version: 1.0.77.0
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/System.Data.SQLite.DLL
System.Transactions
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934
e089/System.Transactions.dll
System.EnterpriseServices
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f
7f11d50a3a/System.EnterpriseServices.dll
CodeBase:
stem.Xml.dll
CodeBase:
stem.Xml.dll
CodeBase:
stem.Xml.dll
CodeBase:
stem.Xml.dll
CodeBase:
stem.Xml.dll
CodeBase:
stem.Xml.dll
Accessibility
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a
/Accessibility.dll
Log4Om.Shared
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM/Log4Om.Shared.DLL
System.Numerics
CodeBase:
file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e0
89/System.Numerics.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
