Getting all 2m ssb spots (144.150 to 144.4) coming up as "digital" not "phone.
Is there any way I can change this? I've looked for a band plan editor but not found one...
Cluster spots/band plan
Re: Cluster spots/band plan
The bandplan is a text file which can be edited with notepad.
I did look for something like that in the program directory but couldn't find it.
Where will I find it?
Edit :
I found it in XML format, managed to sus things out and looks like the change has worked.
Edit :
Hi There....
I'm not the most experienced user around, but I have been down this road before...
Click on Settings in the top menu bar, then Options. You will see a pop up menu with all sorts of options....
Take a close look at this pop up... There's an option to check on the little box that says Enable Expert Options.
Once that's done and you hit Enter (I think), you will see all sorts of fields that you can enter and edit with just something simple as Notepad. Be sure to save whatever you have edited by clicking on the file.. Save and then clicking on the big floppy disk at the bottom right.
Hope that helps...
All the best and 73 and Aloha... Steve.. KH6CT/W4
Hope that helps...
