Dear Daniel,
Not sure it is a bug or not but I think so.
I don't know if I am the only one facing this issue.
If I turn on in the communicator the Fldigi communication both ways then my PstRpotator control will not work anymore, it means that in Log4OM when I click on the heading button the antenna will not turn while from PstRotator directly it is working.
If I switch off fldigi and the fldigi communication then it will work as expected.
Is there any conflict with the communicator if both Fldigi and PstRotator are configures ?
Config is :
- Log4OM 1.18.1
- FTDX 3000
- Yaesu cable from Radio to G1000 DXA for control
- Micro Keyer II (2 CAT available)
Rotator control
Rotator control
73 de F4BPO Greg
Re: Rotator control
never seen this issue... can you check what port is in use in FLDIGI inbound and PSTROTATOR. Those ports should be different.
Can you check / send me your program log after you have concurrently started both systems? i can check here for malfunctions.
Re: Rotator control
Sure the ports are different, FlDigi is 7362 and Pst is 12040.
Not sure which log you want me to send you, please confirm
73 de F4BPO Greg
Re: Rotator control
software log
in HELP menu -> show log
reproduce the issue, then show log, save, zip and send it to me (via mail only, some sensitive info could be contained in the logfile)
Re: Rotator control
Any hint about the issue? this can be useful for others searching in the forum for the same issue
