Log4OM causing ( ? ) memory leak in explorer.exe
w5rkn
Post by w5rkn »
I am running Log4OM v. 1.18.1. When Log4OM is running, the memory allocation for explorer.exe keeps increasing, eventually consuming all available memory. If I exit Log4OM, the memory allocation for explorer.exe drops and stays steady. The memory allocation for Log4OM varies slightly but both up and down. Running Windows 7 Home Premium with 8GB memory.
Ron
w5rkn
Re: Log4OM causing ( ? ) memory leak in explorer.exe
Post by w5rkn »
After discovering 5.8 out of 8.0 GB of memory allocated to explorer.exe, Win 7 Home Premium, I renewed a search for the cause.
In my satellite setup, I regularly run SmartSDR, PowerSDR, SatPC32, FlexSATPC, Log4OM and associated programs. Keeping track of the memory allocation of explorer.exe, I eliminated running programs one by one. But the allocated memory just kept increasing.
After having killed all the programs listed above. including DAX and SmartSDR CAT, I noticed MySQL, used by Log4OM was still running. Killing the two processes associated with MySQL resulted in a stable memory for explorer.exe.
After a reboot, I started all the programs listed above except Log4OM. But the memory allocation for explorer.exe was still climbing. MySQL starts with Windows, so I had to kill its two processes. Finally, the memory allocation of explorer.exe stabilized.
So it seems something associated with MySQL and explorer.exe is creating a memory leak which will eventually consume all available memory.
A copy of this email has been posted on the Log4OM Error Reports Forum.
Any ideas, anyone?
Ron W5RKN
Can't you change to SQLite to avoid this apparent MySQL issue?
G4POP wrote:Can't you change to SQLite to avoid this apparent MySQL issue?
Yep, i would say the same...
