Hello.
I installed LOG4OM and I have a Premium Subscriber Bundle with QRZ.com.
Initially, I managed to auto upload a couple of QSO's successfully but for some reason this has stopped working.
The Debug error file shows:-
2014-09-21 13:47:15.5460 INFO: QrzComUpload: STATUS=FAIL&REASON=missing <eor> in record
I have probably messed up a setting somewhere or there is something wrong with my QSO log completion.
Can you assist please?
Regards
Tim M0TSW
Unable to Auto Upload Log to QRZ.com
Re: Unable to Auto Upload Log to QRZ.com
Have you inserted your API Key in the "External Logs" settings ??? Without API Key upload would not work .....
- df5ww.PNG (62.35 KiB) Viewed 4089 times
Hi
Thanks for the reply.
Yes, I have inserted the correct API key and have also double checked that all the Username/Passwords are correct in the Config file.
What I have just discovered is that the eQSL and QRZ uploads work if I use the automatic Start and Stop times, but it does not appear to work if I set the Start/Stop times manually
I will investigate further.
Regards
Tim M0TSW
Regards
Tim M0TSW
Message is strange. Missing <EOR> means the record doesn't end with the <EOR> tag, but this should be indipendent from timing...
i'll make some checks.
Thanks for reporting
Hi All,
I'm having the same problem with a significant difference. Some of my new automatic uploads to QRZ.com fail this way and some do not. The QSO will not upload manually either. Also some entries for old QSO with manual time entries fail in this way but some upload just fine. Would it help to upload a log entry that fails?
I have an paid XML QRZ.com account. My eQSL uploads seem to work just fine.
The laptop I use is an old low performance XP machine.
What can I send to help resolve this problem?
73s
Joe
73s
Joe
sorry for late answer.
Can you send me a logfile (program log file) when you have issues uploading data?
