"Net Control" logbook operations ...
J85K
Post by J85K »
The Utilities / Net Control feature allows one to name 'Nets' and operate sessions. :?:
1) Is the 'SAVE QSO IN LOG' feature intended only as a 'Net Control' log snapshot?
2) How do I integrate the final session log contents to the Primary QSO logbook?
2) Where do I see the signal reports for each station that I have saved?
Thanks and 73,
Kumar_J85K
J85K
Re: "Net Control" logbook operations ...
Post by J85K »
Hello Daniele and Design Team,
I don't know if I have described my difficulty adequately. :(
I have great use for the 'Net Control' feature as I run several different nets here in the Caribbean. I am not seeing the contacts in my general log after closing the net session. The signal report feature needs to also be incorporated in the dialog box that appears when you click the 'Plus' sign or when you 'double click' an entry in the 'Active Operator' section; and should show the report saved and allow for correction/adjustment of that value.
It would also help if the entries followed a numerical sequence, such that I can see at a glance how many check-ins I have had. Some of my net sessions can garner sixty or more check-ins.
Thanks and regards,
Kumar_J85K
Did you watch the YouTube video that I uploaded?
http://youtu.be/rWLqnUgSumE
You might like to uncheck the "Persistent Net" check box to save littering the HRDLog.net display with inactive nets
Untitled.tiff
Untitled.tiff (93.12 KiB) Viewed 4106 times
J85K
Post by J85K »
G4POP wrote:Did you watch the YouTube video that I uploaded? http://youtu.be/rWLqnUgSumE
Hello Terry_G4POP,
Yes, I done so now!
I note that on your Log4OM main page screen, you have only two 'Green' status buttons for your Comm services.
Mine are three:- namely, Yellow, Green, Shaded Red / Start WCF.
Could this be responsible for my situation?
Thanks,
Kumar_J85K
The com services status will not effect the Net Control
