After installing Log4OM on my PC that is equipped with an NVIDIA GeForce 7025 video card and an HP2311x Wide LCD Monitor, I am not able to get a normal display, without seeing some of the display being clipped off and hiding certain window areas. In particular, the main window featuring F7 through F11 tabs are partially covering up some of the log entry features above it. This is happening regardless of any of the monitor's screen resolution settings I choose, from the lowest to the highest. In addition to this the script (font) displayed in the Spots table to the right is being clipped.
When I installed Log4OM on a second PC here that uses a Optiquest2162wb monitor, I have none of the above problems. Everything displays correctly.
Any help with this would be greatly appreciated.
73, Bob KW4CQ
Monitor Display Problem
Re: Monitor Display Problem
Check your font size in Windows setting.
You have probably a 125% font size in display settings
Yes, that was the problem all along. I reduced it to 100% and everything is AOK now.
Many thanks for the help with this.
73, Bob KW4CQ
73, Bob KW4CQ
