Unwork Mode filter doesn't work
VE3VEE
Post by VE3VEE »
The "Unworked mode on Spot band" filter doesn't work. Enabling/disabling this feature has no visible effect on what I see in the main cluster window. Several versions ago, I did use this feature on a few occasions, and it did work as expected at that time.
Thanks for your hard work! LOG4OM is excellent software!
73 Marvin VE3VEE
Re: Unwork Mode filter doesn't work
Yes I think you are correct!
BTW you can uncheck the mode boxes at the top because when none are checked it is like saying "Show all modes"
VE3VEE
Post by VE3VEE »
Thanks Terry.
73 Marvin VE3VEE
P.S. Normally I only have CW and PHONE checked. I checked also DIGITAL, before taking the picture, just to test the filter feature one last time before posting.
VE3VEE
Post by VE3VEE »
FYI: Issue is still present in the new version 1.20.
I'm working on that right now.
It's a bit complex to fix :?
VE3VEE
Post by VE3VEE »
I just tested this in the new version 1.21.0.0., it is still not working.
I'm working on that in this moment, but the issue is not reproducible here... :evil:
VE3VEE
Post by VE3VEE »
Daniele, thanks so very much for taking the time to look into this issue. It works perfectly in the new version 1.22 released today, June 19, 2015.
73 Marvin VE3VEE
VE3VEE wrote:Daniele, thanks so very much for taking the time to look into this issue. It works perfectly in the new version 1.22 released today, June 19, 2015.
73 Marvin VE3VEE
Another happy camper! :D :D :D :D
