JT9 mode
WD9INA
JT9 mode
Post by WD9INA »
I am using LOG4OM version 1.16.0.0.
Every once in a while the mode notation will not show up in the log for JT9. I have tried to enter it but there is no JT9 in the mode list and I have tried to find other ways to edit the field but nothing works. All I have is a blank mode column in the LOG4OM log.
My log entries with this mode deletion will not confirm on LoTW.
I have about 10 entries that need to be edited. Any help would be appreciated.
Re: JT9 mode
Options
First configuration tab
Select expert mode check box
Click "Modes"
Add the mode that you need
Restart Log4om
The mode will now be in the mode list so you can edit the ten QSO's
HOWEVER YOU NEED TO UPDATE TO LOG4OM 1.19 AS SOON AS POSSIBLE
WD9INA
Re: JT9 mode
Post by WD9INA »
Thanks, that worked.
I have been thinking of putting in the new version but am not really clear on how to save the log data so I can put it back into the new version. Will I do this by saving it to a Adif file and then reloading it into the new version?
Computer work is not a strong suit.
Re: JT9 mode
Remove the old version before installing the new version
Make an ADIF backup for security
All of your settings and log should be preserved when you install the update
