Hi All
Please take a look at the 2 attached screen shots.
Shows all the cluster for 12m and the next with the 3 filters applied. I was expecting the filtered version to show (more stations) all the un-worked mode slots but it does not. (un-worked modes for me are red).
I am sure it did in the past.
Any ideas.
Martin- G6VMR
Cluster Filters 1.19.0.0
- Cluster 2.JPG (41.27 KiB) Viewed 5667 times
- Cluster 1.JPG (192.47 KiB) Viewed 5667 times
Re: Cluster Filters 1.19.0.0
Remove the check mark from "Unworked mode on spot band" to achieve what you require
That then only shows unworked countries and unworked bands for worked countries.
Should it not also show unworked modes for worked countries by ticking the 3rd box. I am sure it did originally.
Unworked mode on spot band does not seem to alter much at all ??
Might be be but not so sure.
Martin
Martin
HI
I have done some more screen shots tonight. I think there is an issue with the filter code.
Have 5 attachments for all variations and none show just my missing mode. Reunion (FR) is an unworked country mode for me.
Martin
Martin
- Capture 3.JPG (35.13 KiB) Viewed 5617 times
- Capture 2.JPG (31.27 KiB) Viewed 5617 times
- Capture 1.JPG (74.71 KiB) Viewed 5617 times
Attatchment 4 and 5
- Capture 5.JPG (34 KiB) Viewed 5616 times
- Capture 4.JPG (30.87 KiB) Viewed 5616 times
Hi All
Responses seem a little low to my post.
Any one else having the same issues. Is it me or is the filter not working correctly ?
Martin
Martin
Hi Martin, to have a chance to fix a possible error i need to have a way to reproduce your exact situation and your exact cluster status, that is impossible at this time.
I'm checking code to see how and if i can find issues on it, but i will be pleased to have feedback from other users too, if they think there is an issue.
Anyone?
Anyone?
Thanks for having a look.
Martin
Martin
Happy New Year!
The "Remove Unworked Countries" is an overall indicator and is not band/mode specific. If red, it means that you've not worked that country on any band or any mode.
