in the statistic and awards, in the other awards (as for example WAE) I cannot see any qso confimed, as it was not enabled any reading backward qso already done.
The process is different for tabbed award as DXCC, IOTA etc
In the "Awards other" like lighthouses, WWFF, Japanese Prefectures, HUMPS etc you need to associate the award at the time you make the QSO by selection from the input window awards tab.
You can bulk update the historic QSO's but this is more complicates as you need to add the award string to the QSO field "QSO Award"
You can also do this retrospectively by double clicking on the logbook entry.
This brings up another window. Go ta Awards and add the award there in the normal way if it is valid.
