I've looked through the manual for a solution to this but have not had any luck.
I am using WintelnetX to accumulate spots from to instances of CWS and one instance of VE7CC. All the spots show up on the cluster connection tab with -# for those generated by skimmer or the RBN. These spots do not make it to the actual cluster display.
The scripts for WintelnetX have an option to strip those characters but they still show up.
Any ideas how to resolve this?
Tnx and 73
Greg
AB7R
Skimmer spots
Skimmer spots
Greg - AB7R
Caldwell, ID
Greg - AB7R
Caldwell, ID
Re: Skimmer spots
I have been using Wintlenetx with log4om succesfully skipping the # filter
have a look at
http://gofrc.org/RBN/WinTelnetX_Configu ... ctions.pdf
have a look at
- Immagine.jpg (63.16 KiB) Viewed 7604 times
73 de Don IK2EGL
Re: Skimmer spots
Version 1.20 when released has reverse beacon network and CWSkimmer support as below.
In the screen shot below I am using WintelnetX to combine (Aggregate) VE7CC and GB7MBC telnet clusters with spots received on my CWSkimmer and the spots received from the Reverse Beacon network - The data from these four sources is combined in WintelnetX and forwarded to Log4OM
All of the spots shown in the Log4om Cluster F9 window that have entries like "20db 23 WPM CQ" in the Note column either came from the RBN or my CWSkimmer.
WintelnetX currently works with Log4om 1.19 if you are only combining normal DX Telnet Clusters, it does not display RBN or Skimmer spots in the Cluster F9 window
- Untitled.jpg (915.43 KiB) Viewed 7570 times
Re: Skimmer spots
Terry, that looks like a great new feature. Can't wait!
Doug - W7DRM
Doug - W7DRM
Re: Skimmer spots
how are the cwskimmer spots added? where is the "how to" in the manual please?
Rob
HB9ETR / G0IFL
Win10 i5-11400 @ 2.60GHz
HB9ETR / G0IFL
Re: Skimmer spots
Hi
they are now passed to the dxspot windows (f2) and you can see it
in the note you will see the same info that cwskimmer provides
before the release 1.20 skimmer spots were not passed
73 de Don IK2EGL
Re: Skimmer spots
Here is an instruction sheetHB9ETR wrote:how are the cwskimmer spots added? where is the "how to" in the manual please?
- CW Skimmer set up.zip
- (379.33 KiB) Downloaded 374 times
