Partial database export
I want to be able to export an ADIF containing only selected database records (using "Search Parameters" in "Recent QSOs") but I can't figure out how to do this. Can it be done? My purpose is to have a separate database containing only SKCC QSOs. John, VA3KOT
Re: Partial database export
You should use the "QSO Manager"
set your search parameters
click search
Highlight the records to be exported or click select all at the bottom of the window
Click the to ADIF button on the toolbar........
click search
Perfect, thank you Terry. Problem solved.
John, VA3KOT
John, VA3KOT
