Dear colleagues, I would like to present two ideas:
1 I think it would be nice if within the statistics if we make a double click in cell it could show the calls; ie imagine I have an "X" on 6meters on CW, if I click this cell than it shows all the contacts on 6 Meters cw mode for that entity.
2 Possibility to show the Bearing in cluster according a given rotor offset in case we are working with antennas in same tower but with an offset of 90º
How it can be done?
On "Options / Settings" in "Station Info" we could have a labels where we put the offset in the bands; ie imagine that I have a tribander mounted in right position but above I have a 2 element for 12 and 17 meters with and offset of 90º, so on 12 and 17 meters the offset would be 90, and for the tribander the offset is 0.
The bearing inside Cluster shows the value according the offset for the bands with offset >0
I hope you can understand my idea, inspite is a bit difficult for me to put it clear in English.
73 Manuel CT1BXX
Double click on Statistics and Rotor Offset
73 Manuel Fernando CT1BXX
Re: Double click on Statistics and Rotor Offset
I suppose we should send to the rotator the same angle, and add to the incoming qrz/hamqth queries the same value?
About "click on the cell" where you suppose to have this? what screen/function?
Daniele
Daniele
Regarding Item 1 I think Manuel is referring to the awards tabs - IOTA
The double click to show entries window does not work when clicking on cells - This is already in Mantis
Hi
I am sending a picture in order to explain the idea.
Nice to know that we will have also IOTA has Terry has told.
My very best regards to all and thanks
73 Manuel - CT1BXX
73 Manuel - CT1BXX
