Filter/Highlight by Missing eQSL/LOTW
K2RAS
Post by K2RAS »
When reviewing cluster spots I look for countries where there is no confirmed QSL from eQSL and/or LOTW. Is there some way to filter and/or highlight spots to identify by country (not band or mode) any missing eQSL and LOTW confirmations?
Thanks, Ron
Re: Filter/Highlight by Missing eQSL/LOTW
yes, first 2 tab of STATISTICS can be properly configured to show whatever you need (i hope :))
IW3HMH wrote:yes, first 2 tab of STATISTICS can be properly configured to show whatever you need (i hope :))
He is referring to DX Cluster spots Lele
Sry i can't understand...
in cluster settings you can highlight spot based on "country, qsl received, eqsl received, lotw received, lotw or qsl"
You can set flag on "Remove Wrkd countries" on "Filters" to keep only unworked countries, where worked is defined in the highlights section (filter).
"EQSL OR LOTW MISSING" is not currently available as filter
You should choose LOTW or EQSL, or another of the filters listed above.
I'm still missing something?
i suppose yes :)
