December SOTA updates missing
Moderator: OE6CLD
vk1di
Post by vk1di »
Tried to log a contact with a SOTA summit added recently on 1st December, does not seem to be listed yet. It is a new VK2 summit, VK2/ST-053.
When are SOTA updates updated in LOG4OM?
73 Ian VK1DI
Re: December SOTA updates missing
Go to the settings menu to update SOTA
I suggest that you turn on auto update and set the update intervals in the options menu
Please let me have the call sign and SOTA reference of the one you are refering to
vk1di
Post by vk1di »
Tried Settings, SOTA Database, Download Updates, after a while a dialog box popped up indicating updates complete.
Still missing the new SOTA summit. The summit is VK2/ST-053 Mt Mundoonen. The last entry in LOG4OM for Australia - NSW / Southern Tablelands is VK2/ST-050. Several summits were added to the SOTA VK2 association on 1 Dec so not just this one missing.
Ian VK1DI
vk1di
Post by vk1di »
Problem solved. After downloading the SOTA Update tried restarting Log4OM, after a program shutdown and restart the missing summits appeared okay.
Regards
Ian VK1DI
Sorry Ian I should have said a restart was required because the summit list is loaded at runtime
I'll check if i can load on update...
